Custom stick mode; wrong direction
3365 11 2018-2-3
Terp1234
Flight distance : 50906 ft
I'm flying the Spark only very recent, but follow this forum for quite a while. The Spark is really fun to fly. I'm getting used to the controls, but for myself I thought the yaw controls on the sticks felt a bit unnatural in Sticke Mode 2. So I tried the Custom mode; on the right stick forward/backward and turn left/right and the left stick with up/down and move left/right. What happens now on the left stick when I push it to the rght, the Spark moves left and vice versa. So just the other way around as the stick movement. When I change the move L/R to the right stick (like in Mode 2), the stick behaviour is normal again. Anybody else seen this behaviour? It's on both when I set it by iPad Mini or Galaxy S8. Not a really big deal, but looks like a small bug in the Custom mode.
2018-2-3
A CW
Flight distance : 15283773 ft
Interesting though I always use mode 2
2018-2-3
TexasAerials
Flight distance : 566952 ft
The reversing in your controls comes from the order in which you touched the "destination" locations for your right stick.  You needed to select "yaw left" and then click on the left side of the right stick.  If you touch it to the right side, the control will be reversed.
2018-2-3
Terp1234
I tried that as well. As you can see on the screenshot all arris are pointing outwards. But even if I drag and drop them differently, no difference. It only works properly if left/right are assigned to the right stick.
2018-2-3
BeastMaster_101
Flight distance : 1082992 ft
Mode 2 FTW!
2018-2-3
TexasAerials
Terp1234 Posted at 2018-2-3 09:30
in your screenshot, your left and right yaw controls are reversed.  you need to drag those controls off and then back down, but drag the yaw right to the "right stick ->" side so that it is set up correctly.
2018-2-3
DJT_MVSP
Flight distance : 2018645 ft
Singapore
You can try mode 1 which is just those controls swapped
2018-2-4
SOUNDWAVE439
Flight distance : 115597 ft
This is a user error. Have fun fixing it
2018-2-4
heliman
Denmark
Don’t forget to switch back to mode 2 afterwards. Unlearning a special flight mode later is very difficult.
2018-2-4
TexasAerials
I made a quick how-to on setting up custom controller configurations if you don't want to use one of the standard modes.   Hope it helps.
2018-2-4
Terp1234
Thanks for the reactions, I finally figured it out. Now the stick movements behave like expected. The dragging and dropping sometimes come quite precise... Now I can focus on getting the natural feeling of flying this little bird. It's a bit different then the glider planes I used to fly, but I'm amazed how stable the Spark is in the air.
2018-2-4
Cookster670
Mode 2 is a standard method use for most RC aircraft.    Mode 1 is popular in Australia, but to me it’s not intuitive...especially for a drone/heli.
I would stick to Mode2, so if you venture into other RC aircraft you are already familar with the controls
2018-2-4
