DISABLE Remote Controller from charging phone battery **POLL
816341 816341 2018-2-3
DebG
Flight distance : 30138 ft
I have been trying to find out how to disable charing my phone while the USB is connect to the Mavic RC. I have not found a solution.
Reasons; Drain RC battery, Phone heats up, Phone cpu locks up/crashes, Phones brightness throttles, (not wanting to carry extra power banks, etc.
Others looking for the same fix/option;
floco Avoiding charging your smartphone with the RC?
george_007 Disable USB charging?
Jr. Stafford Controller charging phone battery?
realitycheck Remote charging android phone
Sctcorolla How do you prevent your RC from charging your tablet?
PGP How to Stop RC Unit from charging Android phone?
MBoshoff DISABLE SAMSUNG S8 CHARGING FROM THE REMOTE
ronnietong Mavic controller charging the connected phone..
billhines66 Phone Charging from Remote
Dougcjohn USB w Android, drains RC controller, Fine w iPhone
Philly Phantom Mavic Controler charging phone and draining battery.
jhnix Controller charging the phone?
Dabbler90 Controller charging my phone
Stef Cellphone charging while using OTG connection
s54chris Mavic controller charges android device?
Blue Drone Mavic Remote Charging Phone
Newlands My Controller is Charging My Phone?
BerndM, Controller charging my smartphone??
Mr Spock Android phones and tablets stuck in USB "charging" mode can't select MTP mode!
app Disable Battery Charging ROOT
Fred F RC Contrroller charging the phone too?
Single SelectVote, Total 328 people participate in voting
Your user group with no voting privileges
2018-2-3
A CW
Flight distance : 14754314 ft
Ensure your RC and device are 100% charged before heading out and buy a battery to power bank adaptor if your flying more than 6 batteries and the answer is number 3.
2018-2-3
DebG
A CW Posted at 2018-2-3 14:40
Thanks for the suggestion. That may solve the RC dying but does not solve the other issues.
Still trickle charges. -- Phone heating up, CPU heating up crashing, brightness throttle, etc.
2018-2-3
Buzzyone
Flight distance : 4647913 ft
Use an iOS device, it doesn't charge them!
2018-2-3
BigBird2
Flight distance : 883645 ft
Seems like one diode in the right place on the circuit board would solve this.
2018-2-3
A CW
What issues? I’ve flown 8 flights consecutively before without any issues.
2018-2-4
A CW
But that is on IOS which doesn’t charge the RC.
2018-2-4
LoSBoL
Flight distance : 666483 ft
Yes please
2018-2-4
RocketChap
Flight distance : 902034 ft
What makes you think its a Mavic RC problem? its more of an android problem. It may not be fixable at the RC end given the RCs current hardware.
2018-2-4
RocketChap
2018-2-4
Ivanski
Flight distance : 714977 ft
I fully charge all the devices before flying (use ipad mini 4) and I only have 3 batteries to fly.
I don't have any problems at all. So my answer is 3.
2018-2-4
Ex Machina
Flight distance : 1806362 ft
I'm guessing this is an Android OS  issue that DJI has no control over. Have you looked at this? Requires rooting your device: https://play.google.com/store/ap ... pcharging&hl=en
2018-2-4
rantanlan
Flight distance : 69698 ft
thanks for the link Ex Machina, I'll keep that app in mind.
2018-2-5
Brad Bilger
Flight distance : 14843274 ft
I use an Android and it makes no difference to me.  I don't use the side USB.  I use the USB-A on bottom.  No charging from there.  I tried the side port when I first got it, but as you said, battery, heating....  Haven't had a problem since I switched.  Samsung Note 5.  Android 7.0
2018-2-6
SeanGalbraith
Flight distance : 891404 ft
Buzzyone Posted at 2018-2-3 19:30
It seems to be charging my iPhone.
2018-2-6
AIister
Flight distance : 626647 ft
Brad Bilger Posted at 2018-2-6 16:46
just tried and it's charging my phone from that port as well.   good thing too as phone battery was quite low when i went out to fly yesterday
2018-2-8
Brad Bilger
AIister Posted at 2018-2-8 04:21
well, if mine is charging, its at a lower rate.  When I first started, I used the side port and my phone would get hot.  Now I use the bottom and my phone is nice and cool.  Beats me.  Someone said that the bottom didn't charge and mine acts totally different using that one.  Oh well.
2018-2-8
DebG
2018-2-13
DebG
BerndM, Controller charging my smartphone??Mr Spock Android phones and tablets stuck in USB "charging" mode can't select MTP mode!
App Disable Battery Charging ROOT
2018-2-16
Thoarax
Flight distance : 488484 ft
Just tested on my iPhone 6, plugged into the side of the Mavic Air remote it does indeed charge the phone. Started at 88%, did some chores, when I came back 10 minutes later it was at 90%.
Plugged into the bottom connection via standard apple lightning usb cable, it did not charge the iPhone.
2018-3-10
RimasRS
Flight distance : 3225 ft
Lithuania
Would be great
2018-3-21
Dorset_Horn
Flight distance : 93379 ft
Mine charges the iphone but I haven't tried the bottom USB yet.
2018-3-21
Marian
Flight distance : 340597 ft
Both ports do charge my Samsung Note 8. What I am currently doing before plugging in the phone to the RC is to turn off the fast charging. This helps quite a lot.
2018-3-21
HedgeTrimmer
Info on possible Data Transfer only USB cabling
2018-4-5
miketmtpro
Flight distance : 1883940 ft
Some Android phones and tablets have a disable fast charge option. That seems to reduce the battery drainage on the RC. Works on my Note 8 and Gal Tab S3
2018-5-8
Gala
Flight distance : 8035 ft
RocketChap Posted at 2018-2-4 16:39
It is an RC issue. On IOS this does not happens, just on Android devices. If it was normal would have happened also on IOS devices.
2018-5-20
Danger Lampost
I also use a Samsung Note 8, but I have not had any of these problems. No heating, no crashes, no brightness issues. I'll fly my Air for a good hour (3 full batteries worth), and when I'm done my RC will be down to 2-3 blinking lights.
Can you provide some details like:
  • How long you're flying?
  • Whether you fully charge before flying?
  • What your RC charge level is after flying?
That said, if you don't want to charge your phone while flying, perhaps a data-only USB cable would work?
See:
  • https://www.amazon.com/Data-Only-Audiophile-USB-Ungrounded/dp/B00WFF5FZS
  • http://www.instructables.com/id/DIY-Data-Only-USB-Type-B/
2018-5-20
RocketChap
Gala Posted at 2018-5-20 14:10
It doesn't happen on IOS devices - but it does on (some**) Android devices so you assume its the RC that is the problem - where is the logic in that?
**On later Android devices you have the ability to switch off charging.
2018-5-20
Gala
RocketChap Posted at 2018-5-20 15:19
No, you do not have this option. You only have an option to switch off fast charging.  It will charge anyway from RC but it will not drain it so fast.
2018-5-23
Gala
It is charging all Android devices, latter Android devices will just drain RC faster if you dont disable in phone fast charging option.
2018-5-23
RocketChap
Gala Posted at 2018-5-23 03:31
Nope - on the Sony xz premium for example it gives 3 options when plugging in a USB data cable:
1. Do nothing
2. charge phone
3. Charge connected device.
So its an android issue not a RC issue.
2018-5-23
Gala
RocketChap Posted at 2018-5-23 14:56
1. Do nothing
First of all Android its a phone OS launched for a commercial Android device in September 2008. Any app developed for this OS must work ok for the majority, not only for 1 phone . I do not own a Sony xz premium ( which I dont know if its listed as a compatiblea  device) and DJI did not instruct me or other buyers to purchase a Sony xz premium so that everithing works ok. I only know that I have one phone that its suppose to work ok, but after using one battery for my drone RC is already almost half discharged.
2018-5-24
3-D
Flight distance : 635764 ft
This is an interesting debate.  For me, it doesn't matter.  I've taken 75 successful flights (and one very unsuccessful flight) and haven't had any problems or issues with my phone/controller combo.  My phone hasn't heated up, and my app hasn't crashed.  The only problems that I've had have been firmware related, which is a completely different thread.
I'm using a Samsung Note 4 Edge with my Mavic Air controller
My answer to the question was 3.
It is likely that i'll be switching to an IPad or some sort of tablet soon though.  I'd like something brighter so it's not so difficult to see in the sun
2018-5-24
AlansDronePics
Flight distance : 823163 ft
Guernsey
A simple solution to the problem. Keeps phone and controller fully charged while in use.
https://forum.dji.com/thread-148871-1-1.html
2018-5-24
SubUser
Flight distance : 74140 ft
BigBird2 Posted at 2018-2-3 19:32
No, I have already tried it.
2018-5-24
RocketChap
Gala Posted at 2018-5-24 03:25
First of all Android its a phone OS launched for a commercial Android device in September 2008. Any app developed for this OS must work ok for the majority, not only for 1 phone . I do not own an Sony xz premium ( which I dont know if its listed as a compatibleand  device) and DJI did not instruct me or other buyers to purchase a Sony xz premium so that everithing works ok. I only know that I have one phone that its suppose to work ok, but after using one battery for my drone RC is already almost half discharged.
I'm Just pointing out that there is no evidence for your statement "It is an RC issue..."
2018-5-24
ShadyDealer
Flight distance : 983428 ft
Never had an issue with my iPhones or iPads. Battery life good in general anyway and the remote doesn’t charge either way.
2018-6-20
dbparti024
Flight distance : 3343 ft
I dont see this as a problem, I connect a external Battery to the Micro connector on the controller, and connect the my Tablet or phone the standard USB on the back of controller. In this configuration my controller and Tablet stay fully Charged. One note, I would like DJI to change the Micro USB to USB-C  on there next controller.
2018-6-20
djiuser_RzPtC98IFcwU
I have stopped my Mavic Air controller charging my honor 7 phone by tricking the phone and controller.
This definitely stops any power been taken by the phone. It is an easy mod to the cable.
2018-7-3
2018-7-3
