DISABLE Remote Controller from charging phone battery **POLL
123Next >
83287 100 2018-2-3
plainman007
India
Brad Bilger Posted at 2018-2-6 16:46
I use an Android and it makes no difference to me.  I don't use the side USB.  I use the USB-A on bottom.  No charging from there.  I tried the side port when I first got it, but as you said, battery, heating....  Haven't had a problem since I switched.  Samsung Note 5.  Android 7.0
You are WRONG. I have tried it just now with my new AIR and it charges even when connected from the RC bottom USB.
2018-7-13
Brad Bilger
Flight distance : 14843274 ft
plainman007 Posted at 2018-7-13 21:17
yeah, well my comment was made way back in February.  I've learned since then... and thank you about being so Vehement about it.
2018-7-14
plainman007
India
Brad Bilger Posted at 2018-7-14 04:38
Sorry. I didnt mean to rub it in or anything. I was pi$$ed off generally with the remote battery draining problem with my new AIR that i bought yesterday. My anger with the product performance was just showing through. I apologize.
Found that maintaining the phone at 100% battery is one work around for this problem.
2018-7-14
Brad Bilger
plainman007 Posted at 2018-7-14 07:27
You know.... I've never really thought about it since I always start out with my phone battery at 100%, but when I land after flying with 3 batteries, controller is about 45% and my phone is at 60%.  What would my phone be at if the RC WASN'T pumping power to my phone?
2018-7-14
Exib
Flight distance : 153760 ft
Buzzyone Posted at 2018-2-3 19:30
Use an iOS device, it doesn't charge them!
Easy solution works for me
2018-7-15
plainman007
India
Brad Bilger Posted at 2018-7-14 13:55
Cant say. I today flew 2 batteries worth. My phone was @ 98% and the RC was at 75% after the entire session, go figure. Works for me this way.
2018-7-15
FLM
Flight distance : 55817 ft
Poland
Hi!
Today I flew 5 batteries.  Approx. 20 mins per flight with 20-25% left. After 5 batteries, controller battery: 50% for 100 minutes total flight time.
AC: Mavic Pro - NLD firmware V01.04.0300 (still testing), avoidance sensors off, only landing on.
Controller - latest firmware, stock
DJI Go 4 - 4.1.22 NLD mod. Still testing.
Mobile device - Samsung S8+, rooted, custom OREO firmware. From 70% to 40% for 100 mins flight, screen recording ON, mobile data ON, GPS ON.
App used to disable charging: Battery Charge Limit  https://play.google.com/store/apps/details?id=com.slash.batterychargelimit
This is the only one app which works for me and it really stops the charging to zero mAh. Tested in two ways. I suppose it doesn't work without root, but try and see if..
Before, without this app, after 2 batteries controller had 50% battery left.  I tried to modify the usb cable in all ways, doesn't work so don't waste your time with that.
So far for me this is the only solution but I'm very happy now with that.
Cheers!
2018-8-13
dbparti024
Flight distance : 3343 ft
I dont see this as an issue, I plug my powerbank in the micro USB on the controller, and put my phone or tablet in the full size usb on the back of the controller. This way the controller and phone get charges. I just clip the battery powerbank on my pocket
2018-8-22
Nick1
Flight distance : 248258 ft
Tip: The post by the administrator or moderators shield
2018-8-26
Nick1
My post was shielded? lol
2018-8-26
DebG
Flight distance : 30138 ft
Nick1 Posted at 2018-8-26 11:25
What did it say?
2018-9-1
djiuser_wa6Lp8ic36OE
Ex Machina Posted at 2018-2-4 18:57
I'm guessing this is an Android OS  issue that DJI has no control over. Have you looked at this? Requires rooting your device: https://play.google.com/store/apps/details?id=org.bramantya.stopcharging&hl=en
I'm  not sure what others think about the  constant updating of the firmware, the limitations on distance and height restricted, if an item is advertised being able to reach a maxim of 1.2 oe 2k i expect it to do just that. I have the Mavic Air and f
2018-9-4
nixuspix
Flight distance : 2864974 ft
Latvia
Don't see any big problem using Android device. Can fly 4 batteries on Spark or MA with no hassle
2018-9-6
CompleteNewbie
djiuser_RzPtC98IFcwU Posted at 2018-7-3 13:15
I have stopped my Mavic Air controller charging my honor 7 phone by tricking the phone and controller.
This definitely stops any power been taken by the phone. It is an easy mod to the cable.
I like this! Do you have any more details? Could you share what kind of switch that is? Are there any other parts I'd need to try this cable mod?
Also, how is the Honor 7 phone doing for you? I'm using a Nexus phone that's about 3 years old and believe it's causing RC/connection problems. It might be the phone only has 2GB RAM, but even when all batteries are fully charged (Mavic, RC, Phone) my phone heats up in the exact place on the phone when it is rapid charging.
I'm looking for a CHEAP phone, but with enough RAM and processor to use for my Mavic 2 (only for the MAVIC, would not be used as a regular cell phone for work, etc., wouldn't even have a SIM card or cell service)
Thanks!
2018-9-6
davidmartingraf
Flight distance : 106566408 ft
There's one solution, replicate the wireless OcuSync experience of the DJI Goggles with smart devices. Then no problems with either RC experiencing a draining battery (I've had no problems with RC battery) and overheating smart device (I have seen my Samsung S7 overheat on very hot days).
2018-9-7
thehippoz
Flight distance : 23 ft
Or root your phone and tablet. Xda has almost all models and ways around the manufacturer locks.
2018-9-7
Jimmy Chu22
thehippoz Posted at 2018-9-7 20:23
Hello thehippoz,
Much appologies, but you are wrong, wrong, and more wrong.  You cant root many phones with Oreo.  Especially Samsung with KNOX and others with QFUSE especially snapdragon chips.  Please do little research before spouting for crying out loud.  You want to disable charging?  Easy, just scratch out charge pin in USB plug, so it not make contact and charge phone.  Nobody figure out power not charge phone if power cant get into phone?  Really?  Not have to be engineer like me, simple concept.
Happy Day
Jimmy
2018-9-9
Jimmy Chu22
That working solution for sure, glad to see someone handy on forum for a change.  Good job sir!
Happy day,
Jimmy
2018-9-9
Jimmy Chu22
Hello djiuser_RzPtC98IFcwU
Good job on switch in cord!
Happy day,
Jimmy
2018-9-9
thehippoz
Jimmy Chu22 Posted at 2018-9-9 14:52
Hello thehippoz,
You just put in a custom rom? What's wrong with you lol And if the maker like huawei won't give you a unlock code. There's a ways around that too.
2018-9-9
Jimmy Chu22
thehippoz Posted at 2018-9-9 15:02
I not have Huawei
antirollback, knox, and qfuse work different on different phones.  blanket statements not apply hippo
Happy day,
Jimmy
2018-9-9
fans66488b86
Flight distance : 728235 ft
I believe you can turn this option off in the dji go app in the battery section. For some reason it only shows this option on the ios version of the app.
2018-9-19
fans66488b86
Sorry... it's located under the controller settings section. You can turn the charging off
2018-9-19
fans66488b86
2018-9-19
fans66488b86
Here is a pic of it
2018-9-19
CanonMax
Flight distance : 8953215 ft
mine (iPad 10.5, latest version, latest iOS (12)) is charged! When using the Mavic Air AND when using my Phantom 4 PRO...
Max
BTW before flying I charge my iPad to 100%... then it almost stays 99-100% during flights...
2018-9-23
djiuser_z1za179TamhR
Malaysia
It's 2018 and a fee months away from 2019. They've even launched Mavic 2 pro.
Yet they haven't figure the hell out on how to stop the RC from charging mobile device connected to it.
One flight of 20 minutes leave me with 20% of RC battery. So much for fly more.
Tq DJI
2018-9-26
Drone34
Flight distance : 84091 ft
This option does not appear on DJI GO4 version 4.3.3 loaded on iPhone 8+ or iPad Mini 2.  That said, although I have not monitored for it specifically, I have not noticed an RC battery drain to charge those devices, but will keep an eye out for it.  Usually fly on iPad Mini 2 using USB port on RC.
2018-9-27
Anthony566
Flight distance : 2488944 ft
This is an interesting one as I now use a Crystalsky and this does not take power from the controller and this allows my controller to last for seven MP batteries.
2018-9-30
djiuser_lvuWrUo4ykP2
Flight distance : 277946 ft
For android, it's enough cut the negative wire of the USB cable and solder a 390 or 470 Ohm resistente on it.
Tablet/phone recognize that an USB charging cable is linked, but not enough voltage can pass to recharge the device.
charging led probably turn on, and also the battery icon show charging, but no charging at all.
Made 4 battery with only 40% battery drain on my remote.
2018-10-9
Hope u can see..
2018-10-9
Vendex
Flight distance : 16722920 ft
Bulgaria
Charging device is very good option and is not a problem, just fully charge your remote controller and you're done. I don't prefer to do any kind of modifications and not recommend them.
2018-10-17
cms3717
SubUser Posted at 2018-5-24 11:23
No, I have already tried it.
split the coating on a USB cord to expose the wires. cut the +5v (red) wire and solder in a 440ohm resistor. Done
2018-10-22
Nebuchadnezzar
Flight distance : 3462946 ft
The option for disable charging must be added in all versions .....  too many angry users
2018-11-1
Boffin
dbparti024 Posted at 8-22 11:56
Has anybody else tried this? Does it really work?
I have a 10,000mAH solar power-brick which I use when in the Australian outback to recharge my phone and use the DJI Fly-More car charger for the r/c and flight batteries.
2018-11-2
Flycaster
Thats the answer, just cut the trace or line to the =V line on the data cable. I forget which ones are the +v/return. Google search will define it.
I believe it is the outer two lines +v and ground, and the inner two lines are the Data and Data gnd.
Just cut the +v line.
2018-11-19
HereForTheBeer
Flight distance : 5381368 ft
for people who say it doesn't charge ios device... or suggesting maybe impossible for Dji to toggle something like this, here's some facts:
the RC charges iOS devices at 750mA (upto 0.750 Amps @ 5 volts) and Android at 1750mA (up to 1.75 Amps@ 5 Volts)
i understand DJi's logic, dont want your phone/tablet dying in the field as it is critical part however, the drain on controllers can be very intense.  my mavic air flying with my LG V10 at 100% brightness tears though batteries. i got 6 flights done and i was down to "critical voltage" on my RC and it was still charging...    as for on iOS, 0.75 amps isn't much of an issue.. infact i done 10 flights and still have more than enoguh to do it again next day without charging up the RC..
solution we as a community want from DJi is the ability to toggle it on and off in the Dji go  app option UNIVERSALLY..  or atleast a "reduced charge rate" option ..or both.. toggle to disable charging and a toggle to reduce power when it is charging..
2018-12-17
TC KABREW
Austria
A CW Posted at 2018-2-3 14:40
Ensure your RC and device are 100% charged before heading out and buy a battery to power bank adaptor if your flying more than 6 batteries and the answer is number 3.
why would you need 6 batteries, i would never shoot for that long
2019-1-1
A CW
Flight distance : 13864580 ft
TC KABREW Posted at 1-1 16:34
I know professional pilots who will use over 20 batteries on a shoot...
2019-1-3
TC KABREW
Austria
nice work, well done
2019-1-3
123Next >
