VikramDrone
Flight distance : 543763 ft
India
We are recently procured DJI M210, Zenmuse Z30 and Zenmuse XT each two in quantity. We updated all the firmware’s and start to fly the two drones but one is working fine another Z30 would not initialize fully and the camera just sits on its side after turning on the M210. No signal from the camera and DJI Go 4 showing Aircraft Encoder Error (0x400000) image attached
Z30 Log file.
[ 25.499266] <<<==== INTO SD CARD UPDATE CHECK MODE upgrade ====>>>
[ 25.503979] Firmware packet number on sd card:1.
[ 25.508015] Packet: [/mnt/usb/Z30_FW_V01.00.00.47.bin];
[ 25.513868] New Firmware, version:1.0.0.47.
[ 25.518335] Update mode: Normal
[ 33.522975] [0x1 0]V1.0.58 -> V1.0.60 need upgrade
[ 35.486035] [0x1 0] Firmware upgrade start...
[ 42.728648] [0x1 0] Firmware upgrade success.
[ 45.732613] Firmware Upgrade Done.
[ 45.736540] Result: Failed.
[ 45.740401] Reboot the remote controller and try upgrade the firmware again.
[ 5.286939] <<<==== INTO SD CARD UPDATE CHECK MODE upgrade ====>>>
[ 5.295754] Firmware packet number on sd card:1.
[ 5.300171] Packet: [/mnt/usb/Z30_FW_V01.00.00.47.bin];
[ 5.307446] New Firmware, version:1.0.0.47.
[ 5.313062] Update mode: Normal
[ 13.321204] [0x1 0]V1.0.60 -> V1.0.60 not need upgrade
[ 13.325390] Check Firmware Done.
[ 13.329706] Check Result: Error.
[ 13.333940] Failed to obatin firmware version. Power cycle the drone to upgrade the firmware again.
