today I made some shots with Spark at 60FPS. Spark video (30FPS) was then postproductively converted to 60FPS. The result looks amazing.
Video from Spark (30FPS) was slowed by 50% in Final Cut Pro X. Using Optical Flow, the video was more smooth. Subsequently, slowed video accelerated to "normal" speed. Slowing (OpticalFlow) and subsequent acceleration = 60FPS video was created!
Below I preview video - do not forget to let go in 1080p60!
Looks nice!
Before jumping into conclusions, can you share 2 clips, 1 raw from the SD card and 1 converted? (just 1 scene, not the whole video )
It would be the first time I could really compare these setting.
Hola quisiera saber como configuras la cámara para estos vídeos, hace poco compre mi spark y los vídeos se ven distorsionados, no me quedan bien y la calidad es regular que configuración debo utilizar.? la memoria que tiene el spark es de 16GB
AdamTheGreat Posted at 2018-2-4 12:12
How did you change the speed back to normal after slowing it and using Optical Flow? Did you just remove the "slow" option?
Check out my quick gif There is a quick indication of how I achieved 60 FPS. I had to create a Compound clip.
