KurtVD
Flight distance : 365299 ft
Switzerland
If you go into the IMU menu (Main controller settings > Sensors), in the IMU section, there is a bias value. I've noticed that the last two times when I've calibrated the IMU, this value was noticeably higher before the calibration than after, so my question is: Is this value an indicator about the necessity of having to calibrate the IMU, e.g. if it is very close to zero, there's no need to do it? And if it gets high after every two flights or so, is that an indication that there might be something wrong with it? Since some people seem to go for weeks without calibrating...
