BigBlueTsunami
Flight distance : 503635 ft
When I first started using the hub, I would plug all three batteries in then all three would light up and flash at the start. Then two would turn off and one at a time they would charge until all three had completed. The same thing for placing them in storage mode. During one sequence of charging, I needed a battery to power up the drone so I pulled one that wasn't charged yet. When I placed it back in the hub it flashed the first two leds for a minute, then the fourth LED started flashing at a faster rate. I pulled it from the hub, turned it off and put it back. It did the same thing again. So I unplugged the hub and charged the battery directly with the charger. Now, when I put all three batteries in the hub it never turns two batteries off like it did prior to this incident. It charges and keeps all three on all the time. I'm worried that this isn't good for the batteries or the charger.
What is your experience with the hub? Does it charges sequentially or all three always on? How does it behave when it's set to storage?
Thank you,
Jeff
PS Go Eagles!
