phantom does not answer
770 5 2015-4-28
arturo
Uruguay
Hi every body
I unpacked my new phantom 2 v2, after reading manual and watch several videos I tried a few short flies.
After that I got a problem!
The phantom turned off and when I tryed to turn it on again, it only emited a small click (neither beeps, nor led lights) and NOTHING MORE.
One of the moter smelled a bit like burnt....
Batteries are full charged
Please, help me!!
thank you!!!
arturo
2015-4-28
Northofthe49th
Definitely sounds like a burnt motor or ESC and a failsafe of some kind is preventing it from powering up.  Probably just ironic that it happened after your upgrade as they would be totally unrelated.  There are some posts on here about checking the ESC's if you have a couple small tools.
2015-4-28
nrgwise
If one of the motors smelled burnt, I would remove the battery and contact whoever you purchased it from immediately.
2015-4-28
I. P. Freely
Did you install prop guards yet? Then, perhaps take them off.
2015-4-28
roy
During power on the system does a self check and if anything is major is wrong it will shut down. I would contact the people you bought it from and ask for a replacment since you have only owned it for a short period.
2015-4-28
arturo
Uruguay
thank you!!!!!!
2015-4-29
