overrunning video in sport mode
2418 21 2018-2-4
Cavids
so when I switch to sport mode and go full speedahead typically I will over run the video so the video will lag behind, often even freezing then resuming when I let off the stick or slow down.  Any thoughts?
2018-2-4
Cavids
bump!!  No one else having this issue?
2018-2-5
Cavids
this is a screen shot from my chat with DJI about the issue.  They are saying that video breakup on full speed in sport mode is normal and expected.  The drone is not really designed to run at full speed, only in an emergency!!!
2018-2-5
fansf77370fb
Flight distance : 1008924 ft
I run mine in sport mode 90% of the time. I have never experienced that.
2018-2-5
Cavids
I get it almost everytime, next time I fly I will try and record, but I have a funny feeling it will not show in the recording, I think I will need to have someone film my screen.
2018-2-5
Cavids
I am going to swap to 5.8ghz and see if that makes any difference as  I do also get many issues of the thing telling me there is high interference. in both sport mode and normal mode
2018-2-5
AIister
Flight distance : 626647 ft
use a screen recorder app
2018-2-5
Cavids
like what???
2018-2-5
Cavids
so I confirmed, the recording is fine, I just get screen lag live, so I will try and figur out a screen capture app
2018-2-6
DJI Palourde
Do you experience lag on the videos from the SD card or only on the Live Feed? What device are you using? Are you experiencing the same problem with your Spark?
2018-2-6
Cavids
only lag from live feed, the recordings are fine.  I am using a iphone X.  As for the spark I do not know as I sold it.  I will do a screen recording of it.  Probably not till the weekend, but apparently ios 11 now has screen recording built in so I will use it!!  worse thing about this is I was on the fene about getting the air or the pro.  I went with the air due to the size.  I wanted this as my main video drone as all my other drones are built ones and used just for FPV.  This one replaced the spark.  When I did use the spark, I did get video livescreen lag if I was not using a OTG cable.  However the Air has only been used with a OTG cable that came with it.
2018-2-7
MiniPalourde
Cavids Posted at 2018-2-7 11:36
Damn... I don't think your device is the problem. It's worth more than your Mavic lol...
Don't forget to post your screen recording. Do you have lots of apps on your iphone X? Do you have a lot of unused memory? Is your device slow in general? Usually when people have your problem it's because they're using a 100$ cheap chinese thingy.
2018-2-7
Surface2Air
Flight distance : 167441 ft
To my knowledge my Spark doesn't do it, neither does the Air. This is in reasonable conditions and open area, within 10m-200m. Keep in mind that when I fly in sports-mode, I'm usually too focused on VLOS then looking at my phone to notice if there was occasional lag in the live feed.
2018-2-7
Bekaru Tree
Flight distance : 15513100 ft
South Africa
it is a problem i get sometimes also. Biggest problem is that it is erratic/ not constant. i also fly sport mode 90% of time. If it always gives a problem then fine, i must accept the limitation. But it does not always do this and so i am left wondering why it does so sometimes and not other times. Currently i am exploring proper use of antennaes and drone position relative to drone to try to understand if this is what causes my problem. .
2018-2-7
Cavids
well today I did the whole screen recording, and so here is the link to youtube, you will see multiple times when the video hiccups and lags.  There are times when it gets worse.  Keep an eye on the numbers on the bottom as you will see they freeze when the video lags, this way you will know when it is video lag and when I am just stopping to turn around or adjust
2018-2-9
Cavids
Bump!!! Bump!!!
2018-2-11
Cavids
so spent over an hour on chat with support and  Iwill have to send it in for repair, however they failed to send me an e-mail with RMA instructions, so will have to get back online with them, real pain...
2018-2-12
MaineMavick
Flight distance : 169524 ft
Your footage on the drone won't have lag. The purpose of the phone screen is to act as a viewfinder, it is not an accurate representation of the exact footage captured.
You can lose the feed altogether and the drone will still be recording the actual footage on the SD card.
And just to make this clear, the phone DOES NOT and IS NOT intended to be the recording device or primary storage for your files.
If you do not edit the SD files on a computer you will never have good footage.
2018-2-12
Cavids
I do not think you read my full post.  Obviously the footage from my phone sucks and is not intended for recording.  The footage that the drone records is perfect.  The issue is that when flying in sport mode I am getting major lag on the live feed.  Many times way worse than on the footage I posted.  I only recorded footage from my phone to illustrate the issue.  This has never happened on the many mavic pros's I have flown and do not and can not be accepted as normal.  Even when I had a spark, as long as  Iwas running the OTG cable I never experienced video lag.  Now without the otg cable I did, so I made it a point to never fly without the OTG cable.
2018-2-12
Dalford
Flight distance : 619846 ft
AIister Posted at 2018-2-5 11:12
What is the screen recording app?
2018-2-12
Cavids
actually the latest version of Apple iOs has it built in, just go to your control panel and there is a record button, so hit record then go back to dji app and fly, when done flying go to control panel and stop the recording.  The only issue I had was it recorded landscape, and when I tried to play it it was sideways, so I had to rotate it in a editing app.  Other than that it worked like a charm.
2018-2-13
Cavids
So I thought I would give an update.  Got the Drone sent off to DJI.  It returned a couple of days latter, and it still does the video lag thing.  No real rhyme or reason.  Only does it when going full throttle in sport mode, and of course the farther away the worse it is.  So I will contact them again, but at this point I am guessing this is just how it is so I will probably ebay it and get a pro...  Didn't want the size of a pro but I personally cannot be comfortable with the video lag
2018-3-11
