DJI Thor
Flight distance : 13602 ft
Necroscope, do you remember the specific message about the disconnect? If the app said the aircraft disconnected, it means the drone and RC disconnected, in this case, you will not be able to control the drone, so it should not be your issue.
If the app showed disconnected, that meant the app hadn't connected to the RC, in this case, try to reconnect by rebooting the app or plugging the cable again if it is mid-flight. And for now, if the issue happens again, you might need to try another connecting cable, reinstall the latest app by scanning the QR code on the official website, please note to do a backup like syncing the flight record and saving the pics and videos before your reinstallation. Also, make sure the firmware of the drone and RC is up to date. |
