Question to the DJI Support
i bought and activated Ocusync Air Unit in the USA (FCC-Mode i asume). Now that i'm back in Europe - how can i swith the Air unit to CE-Mode to fly legally?Or will it switch to CE automatically with next Firmware Update?
CE-Mode limits your frequency range between 5650-5850. If you can get away with it, stay with FCC. Otherwise you can try DJI Assistant 2 and update the nation code.
Hi there, the Ocusync Air Unit does not support to switch FCC and CE manually. Please try to connect with DJI Assistant 2, the nation code will be updated automatically.
