P4 upgrade to V02.00.0700 Update Failed
3785 10 2018-2-5
Plazmo
Hello
I have a phantom 4 and am running DJI Assistant 2  V1.22 for Windows. DJI Assisstant sees the Phantom and suggests an update to V2.00.0700. The Update downloads but the transmission fails and gives me an 'Update Failed' message. I've attached the log.
Any assistance appreciated.
2018_02_05@12_44_43.zip
4.62 KB, Down times: 8
2018-2-5
Aardvark
Flight distance : 384432 ft
This seems to be a common problem at present. You could update using DJI Go 4 App' if you wish.
2018-2-5
DJI Susan
Hey Plazmo, could you refer below and export the upgrade log? We need it for further analysis, thanks!
Assisstant 2(Windows) C: /Users/XXXXXX/AppData/Roaming/DJI Assistant 2/upgrade_log
Assisstant 2(MAC): ~/Library/Application Support/DJI Assistant 2/upgrade_log
2018-2-5
CAOA
Colombia
Hello,
My P4 is useless as it lost video feed when trying to fly. Went to upgrade it and got worse!! my drone now shows the message "Processor chip critically overheated. The aircraft will power off in 30 seconds"  - it does not power down. Also the gimble is totally disconnected - none of the camera functions are accessible in the app. SD card not detected  and the LED above the micro SD slot is flashing RED RED GREEN GREEN over and over. Need to update but always fails. I have tried to update the software 30 times through the app and with Assistant 2 and it fails at the exact same place on both platforms. downloaded DJI ASSIST 1.22 from mavic as a youtube user suggested and no luck. MAC, PC, Tablet.. and all fail, different cable....Any help appreciated.
2018-2-18
djiuser_urWEtRFBVEcn
CAOA Posted at 2018-2-18 20:58
Hello,
Have you found any solutions? I'm having the exact same issue. I called DJI and the told me to update the firmware through DJI Assistant 2 and nothing works for me.
2018-2-22
tokenbrit
Flight distance : 384094 ft
You may want to try uninstalling the DJI Assistant software from your computer and downloading a fresh image from DJI. Also make sure the cable you use is high quality.  This has worked for me.  Good luck.
2018-2-24
djiuser_GW0LqGp6MpTa
Hello,
I am having the exact same issues, did you ever find a solution?
2018-8-25
fans368921ec
Downgrade it to the previous firmware. And upgrade it again make sure you have a full battery
2018-8-25
antonoprianto
Flight distance : 395240 ft
Indonesia
Hello,
My P4 is useless as it lost video feed when trying to fly. Went to upgrade it and got worse!! my drone now shows the message "rocessor chip critically overheated. The aircraft will power off in 30 seconds"  - it does not power down. Also the gimble is totally disconnected - none of the camera functions are accessible in the app. SD card not detected  and the LED above the micro SD slot is flashing RED RED GREEN GREEN over and over. Need to update but always fails. I have tried to update the software 30 times through the app and with Assistant 2 and it fails at the exact same place on both platforms. downloaded DJI ASSIST 1.22 from mavic as a youtube user suggested and no luck. MAC, PC, Tablet.. and all fail, different cable....Any help appreciated.
haiii is the same problem with me, please help may day may day
2018-9-13
Hansi95
Flight distance : 458415 ft
Even this is an old Thread and Im not able to create a new, own one.. I got the same problem. Didnt use my P4 for a long time and have Firmware 1.xx.xxxx. Tried to Update via DJI Assistent 2 (several Versions) i'll only get an Update Failure after Downloading 100%. When trying over the DJI Go 4 App and via remote there is no update available, only for the remote, but I saw some people having issues updating the remote first. When i click update in the app it only checks for an update and then nothing happens, the update button reappears. Tried factory reset as well, tried with and without formatted / non formatted sd card, tried some restarts and reinstalls from app, Assistent, pc, drone, remote, everything. Maybe someone can help me, because im not able to use my drone at the moment.
2019-3-22
Hansi95
Ah, sorry for double posting: In the app i can see a live view from the drones camera, and in the information it says: update is installing, dont fly before the firmaware has been updated (something like this). And im not able to connect my iphone x via OTG cable, nothing will happen then.
2019-3-22
