UV filter
769 6 2018-2-6
Bashy
Flight distance : 2354357 ft
Hi folks, i am goign to assume that the standard filter on the p4p is a UV filter? either way, is the glass or plastic supposed be loose, i.e. when you remove the filter is the glass supposed to fall out of its frame?
2018-2-6
Bashy
2018-2-6
FarmerMac
Flight distance : 1215079 ft
Denmark
The one on my drone is do not fall out.
2018-2-6
Aardvark
Flight distance : 384432 ft
I just had a look at my P4 with the standard DJI U.V filter, looks like it is just an adhesive around the edge, so yours appears to have come unstuck. I wonder if you could get a thin 'O' ring of the right diameter to hold it in place, or a very small dab of glue round edge.
My DJI ND filters appear to be the same.
2018-2-6
Bashy
Thought that was the case, been like it since it was passed on to me, it fits ok cause it centers itself, its just a bit of a pain so i spose  dab of super glue would do it but would nee to be very careful as not to get it anywhere but where i need it cause of the thread....
2018-2-6
A CW
Flight distance : 13978875 ft
It's a glass UV filter on the P4P and no, it is not suppose to fall out. They are more expensive than the ND filters to replace too.
2018-2-6
Rodger8
Flight distance : 20145135 ft
They use to use an "O" Ring to hold the element in but it was binding and making the filter difficult to remove. I replaced mine with a Polar Pro UV Filter.
2018-2-6
