best camera settings dji mavic air
12Next >
65596 59 2018-2-6
Jos A
Flight distance : 11588 ft
some expert tested the mavic air
2018-2-6
Jos A
Suggested Camera Settings
Easy Workflow : Color - D-Cinelike / Style - 0, 0, -1
♥ Best Quality (IMO) : Color / D-Cinelike / Syle - 0, -3, -2 + contrast LUT in post
Suggested Gimbal Settings :
Yaw Movement Limit - 35Max
Gimbal Pitch Speed - 9
Extend Gimbal tilt Limit - Yes (to tilt up)
Gimbal Pitch Smoothness - 19
2018-2-6
Montfrooij
Flight distance : 2235919 ft
Yes, that is a great tutorial if you aks me.
2018-2-6
ianpatrocinio
Flight distance : 388199 ft
Philippines
nice tutorial
2018-2-7
fans69d4f866
Philippines
Just got my mavic! Gonna try this later, thanks!
2018-2-7
A CW
Flight distance : 13838848 ft
Yes, this is an excellent tutorial
2018-2-7
SOUNDWAVE439
Flight distance : 115597 ft
Very informative! Thank you for sharing mate
2018-2-7
GoldenSun
Flight distance : 681903 ft
Poland
Awesome video, great find! Thanks for sharing!
2018-2-7
Surface2Air
Flight distance : 167441 ft
Thanks for sharing!
2018-2-7
MrArtDept
I am new to this, so forgive my ignorance. But I am basically copying his settings just to play around with it, and I see the -5.0 at the bottom, and that slider can't be adjusted. What setting is that for?
2018-2-7
Flying Wolf_NOLA
Flight distance : 345827 ft
MrArtDept Posted at 2018-2-7 07:43
[view_image]
I believe that the -5 is for exposure compensation. While the slider itself  perhaps can't be adjusted, moving the ISO slider or the shutter speed slider above it should move that value (either up - towards the 0 or + side, or more negative - depending on what adjustments you made.
Hopefully I'm correct. I'm sure someone will pound on me if I'm not!  LOL
2018-2-7
Surface2Air
[view_image]
That is your 'Exposure' and is there for reference and can't be controlled directly. You would have to adjust the shutter speed and/or ISO sensitivity to get the Exposure correct (0). In the picture the (-5) means it's 'underexposed' and will result in a darker image then what the camera defines the scene should be in order to be properly exposed, a balance between darkness & brightness is (0). So in this case you would want to slow down your shutter speed (lower the number) and/or raise your ISO sensitivity (higher number) to find a balance where the Exposure number is (0) or as you prefer.. because in some cases a person may choose to underexpose or overexpose an image intentionally for 'artistic' reasons.
Keep in mind though - a low ISO is always preferred and results in a cleaner image, less noise - Used in bright environments. Raise this number to have the camera's sensor be more sensitive to light, but keep in mind the higher you go the more you'll deal with a 'depreciated' image. The first thing you would want to adjust is lower (or raise if the exposure reads +#) the shutter speed, so that light has more time to enter the camera and 'expose' the image more. Find a happy balance to get the exposure meter to (0) or intentionally over/under if that is what is wanted.
One last thing to keep in mind when you shoot video (not photo's). The shutter speed should be double or a factor of itself relative to the framerate you are shooting in (24, 30, ..)
So if I'm shooting 4k at 24 fps (framerate-frames per second) I would want my shutter speed to ideally be  at 50 (1/50 of a second.) This will produce 'smoother' footage, it will look proper. Otherwise it will look weird. For 30 fps, a shutter speed of 30, 60, 90.
I don't have any examples off hand, but if you watch a bunch of Mavic footage on youtube and you keep an eye on the background of a shot, like mountains in the distance and you'll sometimes see 'juddering' where the video looks like it's skipping frames. Not smooooth.
I hope this helps!
And if someone can enlighten me as to why in the DJI Go camera settings Exposure is labled as M.M (something Metering?)
Edit:
I wanted to add & this doesn't apply to the Mavic, Air, etc. but lot's of camera's have a way to adjust the aperature too, the opening and closing size of the lense 'hole' (for lack of a better description) to let in more or less light. So in those cases you would find a balance between your Shutterspeed (speed of the opening), Aperature size (size of the opening) & ISO (Light sensitivity) to expose the image properly.
And sorry if I've drifted into territory that may already be of your knowledge, figured this would be helpful to some. And maybe I should have just started a new thread with this subject.
2018-2-7
escore
Flight distance : 670935 ft
Finland
Excellent tutorial!
2018-2-7
andym91
Flight distance : 113166 ft
Pretty cool!
2018-2-7
MrArtDept
Surface2Air Posted at 2018-2-7 09:59
Really appreciate all the information and the time you took to explain it. Thank you so much!
2018-2-7
Desertcruiser
Flight distance : 3424501 ft
Switzerland
A good comparison! Thanks for your work.
Chris
2018-2-7
Gregs77
Flight distance : 22451 ft
Thx for the good info
2018-2-7
KindaichiShota
Bangladesh
nice tutorial.
Keep up the good work...
2018-2-8
Dexter.Zed
Philippines
amazing footage.
2018-2-8
zofiazoey
Pakistan
Google
2018-2-8
djiuser_xy6tc2h3Xuh8
Flight distance : 197123 ft
[tr][/tr]
[tr][/tr]
I agree completely
2018-2-8
slimharry
Hey do you have your best Mavic Pro settings as well for post processing? Thanks
2018-2-8
fansc33cff15
Flight distance : 78465 ft
Thank you berry much
2018-2-8
maggies
Thank you for sharing it with us, it was indeed one of the best tutorials.
_________________________________________________________________________________________________________________________________________________________________________________________________________________
A web developer at PetStreetMall, a place to find quality and affordable pet supplies.
2018-2-8
Silverhammer92
Flight distance : 15869 ft
Switzerland
@Jos A
Nice video, thank you!
Are those settings just for the air or also for the pro? What settings would you recomend on the pro?
You mentioned to put back the exposure while protection the heighs. How do you do that? What program do you use for editing?
Thanks for the Lut too :-)
2018-2-8
Jos A
For pro I just verify with the maker. (Mavic Pro) I use Davinci Studio 14, but there is also a free version.
2018-2-9
Leftyguy
Flight distance : 1282638 ft
Great Info , Thanks
2018-2-9
fans2137a6e6
Excellent instructional video. Big help for a newbee
2018-2-9
Alexurrutia20
Jos A Posted at 2018-2-6 05:10
are these settings for video or photos?
2018-2-9
Jos A
Both, I use 2.7 K and 30fps, style 0,-2,-2 , d-log , camera manual, iso 100 shutter 60 and  Davici Resolve studio for edit and color correction.
I have also a NEAT noise reduction for Davinci if you like for filming like above settings @4k for Mavic Pro
2018-2-10
DJI Bryan
Flight distance : 1134610 ft
Great
2018-2-11
DJI Bryan
Hello Jos,
I have a different menu, so as show in you video ???
2018-2-11
Mavic Ace
Flight distance : 333976 ft
As a still photographer making the jump to video this is a great help.  Thanks.
2018-2-11
Mr Smith
Flight distance : 2993169 ft
Thanks for sharing, great tips! I still see so may people out there who have had Dji drones for a decent amount of time, but have never bothered to mess with the gimbal speed/sensitivity settings or the camera settings. Every time, I just want to go over there and show them how easy it is to make their shots look better.
And I'm definitely gonna be looking into that Neat Video plugin, because to me, that was a huge difference! So much better
2018-2-13
fans8af70312
Flight distance : 2329 ft
I loved this video, until your comment about the shorter distance you can fly from your house without losing transmission. I am assuming from your accent you are here in the US. If so, you shouldn't be flying farther than line-of-sight. Are you telling us that you lost transmission within line-of-sight???
2018-2-14
bernardb
Where can I find the sharpness settings for the camera?
2018-2-19
Jos A
under style
2018-2-19
CKE ENTERPRISES
Nice video, thanks for taking the time, DJI is going to blow peoples minds going forward I am certain of this
2018-2-19
CKE ENTERPRISES
Nice video, thanks for taking the time, DJI is going to blow peoples minds going forward I am certain of this... like all products there is a release then tweaking stage of their products and next you watch DJI explode with incredible things
2018-2-19
Mr Ed
Thanks for the post
2018-2-20
12Next >
