ISO & Shutter JELLO affect HELP
894 4 2018-2-6
Luxury Vue 7
i posted a week or 2 back about a shakey video (now found out its called jello affect, due to the sun exposure) So i got an ND 16 filter, and sadly the video isnt what i want it to be at right now. IT still shakes, can anyone recommend the best shutter rates and iso rates when using ND16 filtes and above? I look at drone videos from my same drone on the internet, and my videos look no where near that good? here is a video in 4k at 30 fps with an ND16 filter on the Xenmuse x3, thanks
2018-2-6
mixchief
Flight distance : 182057 ft
look for a shakey motor and your props for balance, I had exactly the same issue just not nearly as bad
2018-2-6
vonbaron1
Flight distance : 42014 ft
Also check the mounts for the camera also.   There has to be something loose on that bird to move that much.
2018-2-6
vonbaron1
And that light pole was way way to close.....
2018-2-6
Hi, Luxury, sorry to know you are having issues with the drone, please help to verify the following info:
1. Did you fly in strong windy weather?
2. Please check if the vibration dampers and the vibration absorbing board have any damages.
3. Did you fully push the stick? We recommend to reduce the stick output.
4. What is the firmware version? Is it up to date?
5, Did you ever encounter a hard landing or the crash accident?
Thanks for your input.
2018-2-6
