Matthew Dobrski
Flight distance : 1831050 ft
Rob, I'm terrified that you completely missed my point. False assumptions? Perhaps, but softened by a smiley ... Insults? No way ... Aside from DJI policy to hold such informations tightly guarded, I've just tried to explain general reasoning for keeping us (pilots, NOT mechanics) away from aircraft maintenance issues. Nothing personal, and I apologize for badly chosen wording.
Said that ... As OP stated clearly, the aircraft is flying just fine with evidently misaligned motor boom. Apparently she can compensate for different thrusting geometry. I've seen Inspires configured with almost parallel motor axes and no issue whatsoever, I've seen Inspires with ridiculous misalignment as well. Loose clamp ... ah, that's different story, not the case here. Now, in a quad/hexacopter designs you'll see many different motors configuration: straight up, angled inward, outward, twisted ... All with - assumingly - some performance advantages or disadvantages, experts only really knows (or do they?).
Bottom line: the exact angle or perfect alignment is not really that much relevant as long as the propellers don't collide with FPV camera/sensors hardware. Since we (pilots, not mechanics) will never know what is the specified angle/propeller tip height/clamping bolt torque etc., only common sense may be of help ...
This last factor comes with experience and knowledge. Yes, some of us do possess such qualities indeed ...
