Parzival
Flight distance : 3775476 ft
HV_Sparks Posted at 2018-8-3 00:54
We are using a pair of the M210 charging hubs to recharge 6 pairs of TB55's - agreed, it takes ages. We're looking into an "in the field" charging solution so we can run a relay of charging.
An in-the-field solution would be great, but the added cost and weight may be the same as adding three more pairs of TB55s to your inventory. We did that, and our field usage is supported. For two days in a row in the field, I had to get up twice in the night to swap batteries around on the hub, due to it being so slow. The cube gets very hot as well in sequential charging of 8 TB55s. I am buying another hub/charger, but if I add another pair of batteries I will need yet ANOTHER hub. A bulk solution is needed, for sure. |
