Phone doesn’t connect with the RC
543 6 2018-2-7
tristanmavic
Hello
I have a problem because my phone ( an iPhone 7 ) fails to log in with the RC of the mavic pro.
If you know how to solv this problem thank to helping me !
And sorry for my bad English .
2018-2-7
Surface2Air
Flight distance : 167441 ft
Are you using a cable or trying to connect using WiFi?
2018-2-7
tristanmavic
Surface2Air Posted at 2018-2-7 06:55
Yes I using thé câble
2018-2-7
Surface2Air
I have a spark and air, not the Pro - if you haven't already check through this video, also make sure you have the latest versions installed.
2018-2-7
escore
Flight distance : 775568 ft
Finland
I had same problem with Mavic Air and Oneplus 5. After swiching to developer mode on Oneplus it started to work well.
2018-2-7
Andy in SW Fla
Flight distance : 338 ft
My bird has been grounded for over 6 months with the same issue. I gave up. If you find  solution please share.
2018-2-7
DJI Paladin
Flight distance : 318 ft
Hi there.
Since there are two ways to connect your RC and your mobile device, you can connect both devices through the port on the left with the short cable or the one below the RC with using the original cable of your own mobile device. Please note that if you want to use the port below the RC, you should unplug the cable on the left.
Besides, you can also use the wifi mode to connect your mobile device and your drone.
Please kindly view the video below.
2018-2-8
