Propeller Scratch - Okay To Fly?
7129 13 2018-2-7
slyfox0
Flight distance : 118 ft
Is it okay to fly Mavic Air with a few scratches on one of the propellers?
2018-2-7
Tadango
Flight distance : 232359 ft
Yes they are fine. Cracks are an issue.
2018-2-7
TechGooch
Flight distance : 413839 ft
I wouldn't even second guess flying with those!
2018-2-7
hallmark007
Flight distance : 10017858 ft
There are no redundancy for props on MavAir, they cost $9 a pair just think about it.
2018-2-7
GoldenSun
Flight distance : 681903 ft
Poland
Looks pretty fine to me.
2018-2-7
Wachtberger
Flight distance : 261509 ft
To me this does not look serious. Do some hovering close to you and some maneuvers at low altitude. If you don't see any abnormal flight behaviour they should be ok.
2018-2-7
A CW
Flight distance : 14177772 ft
The drone will not crash or malfunction due to using these but you may experience a very slight vibration issue or worse case, slight drift as the blades may no longer be perfectly balanced. You can use them but for the best possible results I would put on another set. Blades are one of the cheapest accessories and indeed, there is no prop redundancy on quads - if you lose one in flight you will probably lose the drone!
2018-2-7
eYeSkYeYe
Croatia
Its probably just unbalanced so if you dont mind a bit of vibration in that motor you good to fly.
2018-2-7
Buzzyone
Flight distance : 4647913 ft
How did the tips get damaged? (More importantly)
2018-2-7
slyfox0
Buzzyone Posted at 2018-2-7 14:05
I think that this may have been caused by one of the propeller guards being not fully locked and loose and one of the propellers hitting the prop guard.
2018-2-7
DJI Paladin
Flight distance : 318 ft
Hi there.
May I know how the propeller scratched. Even though it doesn't look so serious, we do recommend you change another propeller to use for the sake of security.
If you insist to use this one propeller, you can take off the drone carefully into the open air without any obstacles and keep the drone hovering several minutes at a height of 2-3 meters to check if there are any abnormal conditions.
Thank you for your support and understanding.
2018-2-7
slyfox0
DJI Paladin Posted at 2018-2-7 23:27
Hi there.
I am not sure as I did not fly my drone outside. I just unpacked my drone yesterday and it just hovered a bit indoor. One of three options that I can think of.
1. Cosmetic defect from the factory.
2. Propeller hitting a propeller guard that could have been loose.
3. Propeller hitting part of the drone body (someone else on the forum has this problem). However, I have not seen any marks on my drone or the propeller guards.
2018-2-8
Malakai_UK
Flight distance : 536115 ft
Superfine sandpaper and just gently sand the scuff off, no more. If you can check it on a prop balancer just to make sure it hasn't been affected too much would help loads too.
2018-2-8
djiuser_hP3IfBZpTIKD
2021-1-2
