Rickyber
Flight distance : 403488 ft
luciens Posted at 2018-2-10 08:30
The key to accessing the range available is altitude. A lot of range tests you see on youtube, etc., are with the copter at 400' AGL or even less so the range you get at such low altitudes is less than what Lightbridge or Ocysync is actually capable of. I've gone 2 1/2 miles with both my P4P and mavic pro with only a little pixelation starting to show up and a couple bars down on the signal strength, but that was reaching the max height above launch point of 1620 feet. And that was battery limited too, with more batt I could probably have gone at least 3 miles.
But pretty much the limitation is battery and not range. Both Lightbridge and ocusync have really impressive range, especially at 2.4ghz....
I have also experienced good range on my Mavic Pro also at the heights you recommended.
But, the problems is, when you get out to a distance like that, you are basically limited to filming from that height.
For example, if you were out that far and you spotted something interesting below you wanted to film at a closer distance, say at 200 ft., you would probably start to break up in the signal department while descending.
I guess the great thing would be a zoom function in the camera that would bring things below closer.
But, I'm sure a good one would be a pricey venture.
The area Dirtybird was in gave him a great place to achieve optimal distance and also to be able to drop down and get good close up video.
In my area, that is harder to achieve due to uneven landscape, trees, tall buildings, etc.
So, this Summer..........road trips........lol |
