Mavic Air - missing adapter of RC charging port
23565 28 2018-2-7
windgate
I just got my Mavic Air and going through everything carefully. Is anyone else missing the adapter that goes on the opposite end of the USB charging cable that adapts it to the new square type (not sure what that's now called) connector on the side of the remote controller?
2018-2-7
exos
Flight distance : 425486 ft
Did you check in the small bag containing the spare sticks? It's supposed to be there.
2018-2-7
Wachtberger
Flight distance : 261509 ft
Check the little plastic bag with the spare sticks for the remote control. It should be in there. Should it really be missing, you can use any USB to Micro USB cable that you certainly have somewhere in the house to fill the gap until DJI will send you the adapter.
2018-2-7
windgate
exos Posted at 2018-2-7 14:20
My small bag has an adapter that is USB Type-C on the end -- instead of the new square type connector used in the side of the remote controller charging port. It's as though they sent the wrong adapter.
2018-2-7
windgate
Wachtberger Posted at 2018-2-7 14:22
I've now uploaded an image of the connector adapter to my original post. That's what was in the little bag.
2018-2-7
Wachtberger
windgate Posted at 2018-2-7 14:33
Are you sure? That would be a USB Type-C to USB Type-C adapter then. That would not make any sense. Look again at the adapter end, it should be normal Micro USB but not square as the slot in the RC, it fits however.
2018-2-7
Wachtberger
windgate Posted at 2018-2-7 14:44
That is the correct one, it will fit into the RC but the other way round as shown on your picture.
2018-2-7
Bigplumbs
Flight distance : 620164 ft
The charging port on the side of the controller takes a normal micro USB. There was not a square sided one in the bag other than the phone leads. For some reason DJI have used or invented a micro USB with square sides. The adapter you show is the correct one and will fit.Just make sure you plug it in the correct way round by looking at the little tongue in the whole.
I started a thread on this but got no responses
https://forum.dji.com/thread-132913-1-1.html
Dennis
2018-2-7
windgate
Bigplumbs Posted at 2018-2-7 14:50
Okay. I guess what makes it confusing it that the connector they provided to go from the mobile device to the same port looks square (so I thought it was proprietary). So you're saying per my attached photo that I'm fine to use the Type-C adapter and won't damage the RC charging port (as it really is a Type-C connector)? Picture attached.
With that in mind, these two connectors are the same thing -- with just a different shape).
Connector on the left is the adpater they provide that goes on the one end of the USB charging cable.
Connector on the right is the male connector from the cable that goes between the mobile device to the RC port.
2018-2-7
Wachtberger
windgate Posted at 2018-2-7 15:02
Just go ahead, it fits and works. But it is not Type C, it is Micro USB in just a weird shape. Same thing on Spark.
2018-2-7
Bigplumbs
It will be fine I have charged many times just look where the tongue is and put it the right way round
Dennis
2018-2-7
windgate
Bigplumbs Posted at 2018-2-7 15:07
Dennis
Thank you all for the help. I try to be very careful and sure of what I'm doing. : )
2018-2-7
AIister
Flight distance : 626647 ft
"For some reason DJI have used or invented a micro USB with square sides."
they didn't invent it.  this is an original micro usb , i have used them since at least 2009 or 2010.  at my work i needed some 10 foot long micro usb and when i ordered them i got these square ones somehow, the micro-A
"Type A plugs are typically used for connection to “master” devices. Type B plugs are used for connections to “slave” devices. The device itself either features a receptacle that can accept only type B (slave) plugs or both type A and type B plugs (device can function as master or slave). This receptacle is called an "AB" receptacle.
An OTG device can play two different roles and that depends on the plug to which it is connected. If it's inserted by a micro-A plug, then it acts as the host (an A-device). If it's inserted by a micro-B plug, then it acts as the peripheral (a B-device).
The micro-A and micro-B plugs differ in the voltage of the 5th pin (ID pin). A micro-A plug has its ID pin grounded, while a micro-B plug has its ID pin floating. So a device can know which role to play based on the plug inserted.
Since the differerence between micro-A and micro-B plugs is necessary, a device must be able to be inserted by both kinds of plugs. That's why micro-AB receptacles are introduced."
2018-2-7
DJI Paladin
Flight distance : 318 ft
Hi there.
If you still wonder whether you have missed something in the box, you can check the link below which shows What In The Box. Thank you.
https://store.dji.com/product/mavic-air?vid=38961
2018-2-7
Bigplumbs
AIister Posted at 2018-2-7 20:58
Reading your post about the 5th Pin being grounded on the Type A does this have anything to do with trying to stop one device charging the other when plugged in to each other
Dennis UK
2018-2-7
AIister
have only seen that on usb c or lightning so not 100% sure about 4 or 5 pin setups vs the 10 or more pins that the other cables use
2018-2-8
LoSBoL
Flight distance : 666483 ft
Thanks for shedding some light on the port types, it does make a good point as to why DJI opted for the rectangular connection on the Remote.
Still think its a design flaw, it makes for a fiddly and delicate connection which could easily be damaged.
As I recall USB-C could work in both Master as a Slave device. As the Mavic Air itself also has an USB-C connector it would have made perfect sense to also fit that on the remote. It wouldn't have the delicate connection, idiot proof cable insertation of a cable and it wouldn't have to need an adapter which we could easily loose or forget.
2018-2-8
windgate
Thank you for the clarification on this. : )
2018-2-8
Punchbuggy
Flight distance : 483166 ft
windgate Posted at 2018-2-8 18:10
Hi. I just opened the box - it arrived today (yay) - and I have to say that I thought I was missing the adapter too. I'm glad I read this thread, because that little guy is soooo small I completely missed it. I was expecting something bigger. But it's there. Phew!
2018-2-8
Bigplumbs
Don't forget you also have a USB (Big or normal size) on the bottom of the controller that you can also use your OTG cable in if you buy the right size and length one
Dennis UK
2018-2-8
djiuser_UBwK99tkCWBU
I have the same problem.
2018-3-6
fastnboulbous
Same issue here, I got my Mavic Air a week ago and it is missing the adaptor as well. Have laid everything on the table and not there. I am waiting for a response from the supplier but am quite happy to just go and buy one if I could find one. Anyone have link to purchasing one?  Frustrating having the mavic air for a week now and still can't use it because of one little adaptor.
2018-6-14
HerveH_French
Flight distance : 8451 ft
Thanks a lot!
Merci beaucoup pour l'information!
Donc pas besoin de l'adaptateur.
Le connecteur micro USB b male dans le connecteur micro femelle rectangulaire de la télécommande en faisant attention au sens (la petite languette).
Pas réussi à trouver l'info sur les forums français.
Hervé
2018-11-8
djiuser_kZBP8QXRQpO4
fastnboulbous Posted at 2018-6-14 16:31
Same here, missing the little bag containing the adapter and the spare control Sticks.
DJI customer support are just not interested because it was supplied by a third party.
The cost to them must be minimal.
2019-5-14
HERNANDO M.
Colombia
Same problem here, missing the little bag containing the adapter. It is incredible that a company like DJI, which produces high quality devices, makes such elementary mistakes, and the worst thing is that they show no interest in correcting them, because I can see that it is something recurrent.
Please if someone knows the way to obtain the USB adapter, I will be very grateful.
2019-5-24
Same problem
2019-6-10
cutis
Flight distance : 1695351 ft
Whatever unfamiliarities, examine before doing, otherwise you'll set yourself back.
mavic air flyers purchase the usbMicroA cables with legacy pc connector usbA.
it is out there shortest shielded bestest.
since android can be connected direct into rc, i china'd usbMicroA to usbC, as phones samsung are now usbC
Charge from cigarette lighter or utility line i also china'd usbC port outs for the six inch cabling's usbC
You will discover, an even shorter length definitely improves perform.
Removal of mp4 from the soldered in 8gb aircraft storage is mandated by cabled android else pc else chromebook else apple equiv.
here, the three inch cable superior solution, into external reposit via os chosen.
by using longer cable, it takes quite awhile longer, say clearing out 8gb plus sdcard 128gb of ignored offloading
2019-6-10
djiuser_Bsj0YmnWKvsM
I just received mavic air 2 fly more combo. but  remote control charging cable missing . What should I do ? I was excited to receive the drone ,now I am lam duck . Could please send me the cable ?
2020-10-7
2020-10-7
