Mavic Air charging hub - no parallel charging
3834 14 2018-2-7
iceman#1
To who it my concern... I just found out that the Mavic Air batteries are not changing parallel on the 4-battery-charger which comes with the flymore combo. That is nothing new for you guys flying the Mavic Pro, but coming from the Spark, it does matter. Loved the fact, that I could charge 3 batteries parallel for my spark.
2018-2-7
hallmark007
Flight distance : 9827923 ft
Would have been nice, I think we will see another charger down the line as we have with Mavic and phantom and inspire .
2018-2-7
Wachtberger
Flight distance : 261509 ft
Yes, it is a nice feature with the Spark charger, I agree. But as here above stated, things may improve over time.
2018-2-7
iceman#1
So there is a charger for the Pro which can charge parallel?
I don't like the fact that I paid a lot for having the flymore combo and getting a charger which will have a better successor sooner or later. Anyway, let's see.
2018-2-7
Wachtberger
iceman#1 Posted at 2018-2-7 14:46
The regular charger of the Pro does not charge in parallel either. I believe it's a capacity issue. The Air batteries have a bigger capacity than the Spark ones. I don't know more details though...
2018-2-7
DJI Paladin
Flight distance : 318 ft
Hi there.
Actually, the logic of Battery Charging Hub of Spark and Mavic Air is similar.
Spark: 15-45℃, the battery with the lowest voltage will be charged first. When power is enough, there will be multiple batteries being charged at the same time. As a whole, the charging hub will charge all of the batteries with the maximum power in the fastest time.
Mavic Air: The batteries will be charged in sequence according to their power level, from high to low.
You can take it as a reference.
2018-2-7
Gunship9
It would take an expensive power supply for a charger to push enough current for four semi large batteries to charge at once.  Semi expensive at least, but enough to mess up the consumer price point the Mavic is trying to reach.  Likely safer to keep the total current low given how drone pilots will place on charge and forget it.
2018-2-7
frankengels
Flight distance : 2273796 ft
Belgium
Gunship9 Posted at 2018-2-7 22:08
Fully agree with you and additionally this kind of power supply would need active or large passive cooling. I have from RcGeek a 3 batteries parallel charger for my Mavic Pro with a 15 Ampere + rating but it is big heavy and loud due to the active fan cooling . Works great but less adapted for traveling. I am also quite sure that you will find such chargers from third party suppliers.
2018-2-7
Bigplumbs
Flight distance : 620164 ft
This is one of the reasons I don't think the Fly More combo is the best way to buy the Mavic Air
2018-2-7
AIister
Flight distance : 626647 ft
are you kidding?  i walk in , put all the batteries on charge and go to bed.  what is more convenient than that?  in the morning i get up and start charging the other two p3p batteries one at a time.
2018-2-7
Bigplumbs
AIister Posted at 2018-2-7 23:46
I am more than happy to change over myself. Also many would say that you should not charge Lithium batteries unattended. Look at the various advice about this all over the net
Dennis UK
2018-2-7
Cameleon
Flight distance : 60394 ft
As others have stated, it actually makes logical sense when you look at the power draw it would need. A parallel charger would be bigger, heavier and require cooling which would likely make it noisy. Not fitting with the Airs travel aspirations. What DJI have done is pretty clever, keep the power block small and light but allow you to queue up the batteries so you can set and forget and leave them charging. Obviously I would do this somewhere that if they decide to go pop it won't have much impact!
2018-2-8
LoSBoL
Flight distance : 666483 ft
It makes sense to charge in sequence instead of parallel.
I'd rather have the batteries fast charge one at a time, then have it tickle charge them all at once.
Sequential charging will have you flying faster then parallel charging would.
2018-2-8
Colin G4GBP
Flight distance : 42533 ft
I have a ham radio power supply that gives 13.8v to a cigar lighter connector. I put the flattest  battery on the car charger into the ham radio PSU and charge the other two via the sequential charger. The 12v charger is always ready first.
2018-2-8
A CW
Flight distance : 13926112 ft
I have the DJI advanced version of their charging hub for the MPP - when the first battery hits 85% the second battery will start charging so it’s semi simultaneous reducing the charge time on 4 MPP batteries from 15% to 100% by an hour using the same stock charger. The advanced hub is also compatible with the Phantom 4 100W charger as the hub has an internal fan to cool itself - this charges the same batteries in 2.5 hours rather than 5.25 hours with the standard hub. The advanced hub came out later down the line for the MP as an optional accessory and is not in the fly more combo. I think DJI will probably do the same with the Air charging hub once they have sorted everything else out following its recent release.
2018-2-8
