fansa1ac7f93
Flight distance : 36365 ft
Sri Lanka
Hi all,
I have a mavic pro battery[warrenty expired] that had not being used in nearly 2 months. Yesterday I checked it and it was completly dead. [no LEDs]
I plug it in to the charger for few hours but nothing happend then after reading few forum I decided to open the battery and charge it mannully using a lipo charger.
After struggling a lot I finnaly managed to unclip the cover and open the battey. Battery is showing 12v on the lipo terminals. So it can't be dead right?.
Then I decided to remove the balance wire and may be try to reset the intelligent board. I kept the balance wire disconnected for few hours and plugged it in nothing happened.
Then I unsoldered the ground wire and removed the balance wire, kept it for 1 hour and plugged it in ..
To my surprise LEDs came back on and it's now showing all four LEDs ON for 12v. Then I inserted the battery to the mavic and trued on the qaud. But no response from the mavic.
LED power on sequence is normal and it stays on. Then I checked the terminal using a multi-meter and there is no power in the terminals.
Can anyone know how to solve this problem or direct me on right direction.
Big thank you for going through my lengthy explanation,
Chamika.
