lannes
Flight distance : 4465 ft
I've tested the Crystalsky Ultra with DJI Go 4.2.4 for 1.5 hours on full brightness and with the latest firmware for the AC, 3 full flights with the MPP, ambient temp 23c and there wasn't a single glitch in the monitor, this was 4k 24fps, with caching back to the CS at 7gb
The hottest the Ultra panel got on max brightness this time out was 41.5c , the side ports got to 38.6c and the back panel near the ports to 40c.
The CS fan never came on at all during the 1.5hrs and the temp was pretty consistent from about 15min from start up to the end. I am not sure what the normal operating temp of the CS Ultra is unfortunately. A funny thing though the RC fan was humming away after 30 minutes, when in previous longer flight sessions it never came on at all.
DJI Go 4 4.2.4 worked kinda flawlessly, there was no latency or pixelation at anytime in RC signal out or HD signal back, mind you I was using a Titan Cyclone 2.4ghz amplified panel. I think there is a little bit of an issue with the radar, not sure if it was pointing the right way
I think they may have fixed the overheating problem for now, my CS build date it the 15/10/17 for reference, a couple of us who have this build date have CS Ultra's that get hot but have never failed.
The only issue I would like to flag is that the fan does not come on, not sure if it has been disabled or set to come on at a higher temperature range, in comparison the fan in the RC was humming away after about 25mins into the session.
Interesting to see how the other CS Ultra owners are fairing with the new CS firmware and 4.2.4
