Fred F
Flight distance : 4676457 ft
I have Mavic Pro, so I presume it should work similarly.
There is a video cache in the phone, which you can set the limit, if you set "Auto", it will use all available free storage in your phone. This is for the storage of the 720p video transmitted back to your phone as it flies.
The full resolution image ( resolution as defined by your video setting, 4K, 2.7 K etc. ) is stored in the SD card on the drone, limited by the size of the SD card.
I think the "20GB" indicator is for the size available on your on-drone SD card. if you touch it, it'll probably changes to "video time left", which probably is more easy to understand, so you can tell how much video record time you have left, in terms of space available on the SD card.
