Harley Davidson
I went by Harbor Freight, tool store for those that don't know, and looked around the store. I found a hard case with the foam inside and on the top. The foam is cut so you just stick your finger in and pull util you get the shape you want. Mine holds my Mavic Pro, 4 batts, controller, charger, extra blades, and still has room. It was only $30.00 and has 2 holes in the corners when closed for locks. it looks just like some of the more expensive ones I see online. Hope this helps some of you. |
