Ribbon cable cracked or other issue?!
1612 6 2015-4-29
manuelkuijpers
Hi y'all,
Recently my Vision + crashed and now the gimbal isn't working properly anymore.
It's twerking all around. I've tried some things, but then i noticed that the ribbon cable might be slightly cracked or some sort.
Can anyone confirm this on the picture? I've uploaded hd quality, don't know if it's still zoomable
If the cable is the issue i can order a new one and replace it.
Thanks for any potential help!
Greetings from The Netherlands!
http://youtu.be/yP7wnQBF6Rk
2015-4-29
stock12to32
This looks like the same problem you are having.
2015-4-29
manuelkuijpers
stock12to32 Posted at 2015-4-30 04:40
Click this link.
Thanks for your feedback. I did try that actualy, serveral times, but no luck...
2015-4-30
manuelkuijpers
My problem still ain't solved.
I can connect the drone with the software properly, and perform an advanced callibration, but with no luck..
I've ordered a ribbon cable a week ago now, waiting for that to arive.
The ribbon cable can be the problem here?!
2015-5-5
darlox888
Why don't you try to replace a new ribbon cable?  I bought on and found every thing is OK, you can purchase on line from this:http://www.aliexpress.com/item/Free-shipping-Dji-phantom-2-vision-plus-gimbal-ribbon-cable/32329066326.html?spm=2114.31010208.4.2.ZRIRy2
2015-5-19
roy
How did you make out with the twirled camera. Did the cable replacment fix the issue?
2015-5-20
Raybro
Flight distance : 11099 ft
I hope no more twirking.....only Miley Cyrus does that...
2015-5-20
