Wellsi
Flight distance : 8330187 ft
So, just in case you've missed it, the Air comes with a self timer option of sorts. And also in case someone else gets caught out by this (as I spent 10 mins trying to switch it off having unwittingly set it when playing about with the camera settings during my initial set up. )
It's called 'Interval Shots' and the setting is in the main camera settings where you select what type of snapshot you want (eg HDR etc).
I had completely forgotten about it as I had been shooting only video since getting it (trying to pump out the YT vids at the moment Hence I wasted half a battery trying to work out why my camera wasn't working properly . It's actually a great setting to automatically take continuous pictures every few seconds depending on what you set the time to... Allows you to concentrate on flying ...
So, if you see a timer symbol and a 5 or other number in place of your usual button, check your settings.
Will have to check the Pro; I don't remember this setting on that....
cheers
Ian
http://www.youtube.com/ianinlondon
