Remote controller and Assistant 2
15008 18 2018-2-10
towheaded-pilot1
Flight distance : 35125 ft
Can't get my remote to connect to assistant 2. It does show as charging but nothing else. Plug everything with included cable and adapter and nothing. I've got device drivers needed for CDC ACM DATA and USB Serial Device in task manager.
2018-2-10
integer
Flight distance : 113355784 ft
Greece
Try a different usb port
2018-2-10
wworrall
there are two other threads on this isssue, including with screenshots from PC device manager showing details of the problem.
2018-2-10
towheaded-pilot1
integer Posted at 2018-2-10 11:52
I have 4 USB 3.0 ports and 2  USB 2.0 - each one was tested with same result.
2018-2-10
towheaded-pilot1
wworrall Posted at 2018-2-10 14:31
Realized that after I posted.
2018-2-10
Monkey007
Flight distance : 73775046 ft
DJI seems to have quite ambiguous instructions on the firmware update instructions for the Air's RC; it doesn't officially say it can, or can't be updated via the Assistant2. And I was expecting DJI to have added the USB driver package to the DJI Assistant 1.2.2.827, but apparently NOT!
2018-2-10
iceman#1
So far update only works via Go4 app
2018-2-10
towheaded-pilot1
Mavic Air remote should be able to connect to Assistant 2. See DJI support video:
2018-2-11
djiuser_J8pTkMaNyi6H
Flight distance : 3301621 ft
Slovakia
towheaded-pilot1 Posted at 2018-2-11 09:33
Mavic Air remote should be able to connect to Assistant 2. See DJI support video: https://www.youtube.com/watch?v=XPmWvxeSp7E
Yes should be but obviously it is not able at all.
DJI please fix this.
2018-2-12
wworrall
RC connection to dji assistant 2 resolved in my case:
https://forum.dji.com/forum.php?mod=viewthread&tid=134139
2018-2-15
DJI Paladin
Flight distance : 318 ft
Hi Everyone. Thank you for your feedback. We have taken note of the issue for the Mavic Air remote and DJI Assistant 2, and have forwarded it to our Field Application Engineers. We will update you soon once we have feedback.
2018-2-15
Punchbuggy
Flight distance : 483166 ft
DJI Paladin Posted at 2018-2-15 17:57
Thanks Paladin, but can you pass on the similar driver issue affecting access to the virtual storage too please. It looks like the same issue with the drivers.
https://forum.dji.com/forum.php? ... D534%26typeid%3D534  and https://forum.dji.com/forum.php? ... D534%26typeid%3D534
2018-2-15
DJI Paladin
Hi. PM sent.
2018-2-15
djiuser_w0wkVno3vH3U
@ DJI Paladin -
Hello,  are there any news?
Im having the Air quite shortly and untill now I ignored the GO4 app messages about that I need to update the Remote FW. (It was enough for me to do updating the fw for my three bateries ).
Today I decided its time to obey the voice of DJI and exactly according the DJI instructions I connected the Remote to the Assistant 2 on my PC. Again waste time of trying and searching. Now I see that this is a bug known at DJI for very very long.
DJI Paladin shall I perfom that (users invented) workaround (downgrade the Assistant  and upgrade back again to get the working USB driver to my PC) or does DJI have standard solution?
Thank you.
2018-7-28
Joe_CZ
djiuser_w0wkVno3vH3U Posted at 2018-7-28 05:51
@ DJI Paladin -
Just set my nick here  - was djiuser_w0wkVno3vH3U, now its Joe_CZ
2018-7-28
EllaHoll
Ukraine
Thank you for these posts and links.
2018-7-31
OsKArg
Flight distance : 85479 ft
Argentina
bricked rc spark
2018-12-27
djiuser_Oo81jZtVrCCO
Same issue. A few things:
  • Use Dji Assistant 2 (DJI FPV Series). Got me with the goggles.
  • Make sure USB is connected directly the the computer. Do not connect through a USB hub or USB extension cable. Got me with the RC.
Hope that helps.
2022-3-24
FPVrider
Flight distance : 29327 ft
Switzerland
Simple fixes first: You must power on the remote controller before you connect to DJI assistant ;)You say that it is charging after connecting to any of the ports, this tells me that the controller is switched off.
@DJI: Instead of the fancy art work indicating that you just have to connect a USB cable, a few more instructions would really be a good idea...
2023-8-5
