GL300C controller not charging.2 or 1 lights.
2267 2 2018-2-10
ovlovv70
Flight distance : 26020 ft
Reflow this one component which i think is the regulator , will require an air solder iron 400c for a few seconds .With circuit board turned over this 8 leg component sits immediately next to the rubber boot which covers the 5 display lights. If you are not familiar with this solder iron please test on an old circuit board.
I did it and all working fine now.
Need some of you to try and confirm. your results.If you repair your charger please post here to let others know.
2018-2-10
Hellsgate
Flight distance : 1991555 ft
Cannot see the image you posted can you please try again
2018-2-10
ovlovv70
Hellsgate Posted at 2018-2-10 15:54
Could not upload photo.
Go to
2018-2-11
