DJI Goggles with 2 Remotes
719 3 2018-2-10
Mims
Flight distance : 1686991 ft
I have been trying unsucessfully to get the head tracking to work with the DJI Goggles and Inspire 2. I'd like to use it with the slave controller, but I can't get it to work on the master controller either. I have used the Goggles with the Mavic, and it works perfectly. Here's how I've tried to get it to work:
I turn on the controller and the goggles. I then turn on the Inspire 2. I then plug in the micro USB plug into the micro USB slot on the Goggles and the other end into the USB A port on the controller. I can see video through the goggles. I can see a set of brackets that move with my head, but the gimble does not move. I looked in the setting on the Goggles and the head tracking sensitivity settings seem okay. I did not find anything that seems to turn on head tracking. I'm guessing I'm missing something simple.
Once I figure that out, is it possible to connect to the slave the same way so that my camera operator can use it to shoot video?
2018-2-10
Mims
FYI: All firmware (Goggles, remote, Inspire 2) are up to date
2018-2-10
Aardvark
Flight distance : 384432 ft
Mims Posted at 2018-2-10 17:33
Try swiping down on touchpad with two fingers, you will then have options to activate head tracking (I'm not sure what's available for inspire 2).
2018-2-10
Mims
Aardvark Posted at 2018-2-10 18:28
Try swiping down on touchpad with two fingers, you will then have options to activate head tracking (I'm not sure what's available for inspire 2.
That's it! I knew that it was something simple. Thanks for filling in the blank.
2018-2-10
