ESC error - Brand new Spark
1295 9 2018-2-10
Balaji_me
My wife gifted me a Dji spark. I unboxed and linked my phone and RC with the aircraft. However when I try to fly it, I get a ESC error and I am not able to fly my drone. Should I get it replaced?
2018-2-10
ZarcTheSpark
Flight distance : 460676 ft
well... if your firmware is updated, then yes, start a return, in my opinion.   Electronic Speed Control is a motor issue.
2018-2-10
Balaji_me
Thanks Zarc. Yes the firmware is up to date. I will have to get replaced then.
2018-2-10
Gunship9
Balaji_me Posted at 2018-2-10 20:33
One of my models had a new Castle Creations ESC fail on its second flight.  Their engineer told me that if ESC's are going to fail that they would do it early in its life.  He then mailed me a new one.  I have never had a problem with an ESC since.
2018-2-10
S.J
Flight distance : 322454 ft
Japan
this is normal while your props get stuck in an obstacle.  I had the same issue.  just run the spark again at idle and restart GO4 app.If the problem persists simply reinstall the software again..
2018-2-11
DJI Thor
Flight distance : 13602 ft
Hi there, have you returned the drone yer? If you haven't, since you're sure that the drone is running with the latest firmware, please try to restart the drone a couple of times, if the issue persists, I also suggest sending the drone in, contact our support to start a case or contact your dealer if your wife purchased it from the dealer for help.
Here’s the link to contact us: http://www.dji.com/support
Thank you.
2018-2-12
Balaji_me
That's a bit consoling. Thanks Gunship9 .
2018-2-12
Balaji_me
I returned the drone today and got a new one. Charging the batteries right now. Will update the thread soon.
2018-2-12
djiuser_mxp7X0b70XrQ
Flight distance : 5272 ft
Balaji_me Posted at 2018-2-12 02:32
Can I ask how you did it? Do they give you a redemption code for a new aircraft? Do they require receipt of faulty item first? What country are you in?
2018-2-13
rimza
Flight distance : 3307 ft
Brunei
I presume it is a one to one exchange at the shop that he bought it. Normally resellers do honour these considered as DOA exchanges.
2018-2-13
