After update to latest firmware as above, I experienced below two unacceptable bugs. The first one probably is here before v01.00.0200.
1.) The home point is off by 4-500meters! My based location is Hong Kong, but when I travel to China yesterday I discover all my flight record home points are off by 4-500meters. There is an option for Chinese Map coordinates correction but it isn't available for Mavic Air. So I can't imagine if there is a signal disconnect happen how RTH will head to?
2.) As shown youtube link, my Mavic Air after 12mins flight time with normal video and panorama action. It suddenly hang on the horizonal 9 shots panorama. As it can be seem in this link, the process hang during shot and stitiching. The drone has no response to any controller action, but it is still connected because the video feed is live and battery status is declining! After I press RTH, gimeral and camera shake as video showed. But luckily it did back home. After I post on Facebook there are couple guys also reply has same experience.
Please kindly advise are the above two serious problems are hardware issue which should file for return? Or it is firmware buy that will be fix anytime soon.
Berg I Imagery Posted at 2018-2-11 20:38
Have either of you tried a factory reset through DJI Assistant 2? Might want to give that a go and see if it resolves your problem for now.
