RichJ53
Flight distance : 1837356 ft
Breakneckone@gmail.com Posted at 2018-2-11 08:53
I notice that the lead screw feels sort of tight when I cycle the gear manually. And when I try to cycle with the motor you can definitely hear the motor trying to operate but it is stalled. Are there any maintenance instructions for lubricating the lead screw. If so what type type of lub? Would WD40 be out of line
Hi, ..... you can clean the wormgear with TriFlow first. Then use some grease listed below afterwards. I would manually move the assembly a few times to work the grease into it. See if the gear works with the motor drive after all is said and done.
Depending on your environment, this should be something each owner can do for maintenance.
Rich
TriFlow pen
10533 White Lithium Grease |
