Ricky Aerial Photography
"...max motor speed reached...", the ESC (Electronic Speed Control) might overheat and therefore, could not supply enough power to the motors to keep the AC in position. Spark is small and compact. Components that generates much heat, i.e. CPU, ESC and etc, are placed very close to each other inside a very tight airframe. Furthermore, there is not much/enough air intake vents to cool the heated components. This may be a major design fault in Spark, I think.
As the components heated up, all sorts of weird things can happen, e.g. signal breaking up, lost control, suddenly lost power and drop to the ground, flyaways and etc. These problems are often reported in this forum nearly everyday.
As I have suggested in other post, DJI should recall ALL the Spark. It is dangerous to fly. Will consumers continue to buy an iPhone/Android, that constantly crashes, black screen, hangup, overheated CPU and batteries??? An uncontrollable Drone is much more dangerous than using a defect mobile phone. DJI should look into the design fault (if any) in Spark and give each DJI Spark supporters a good replacement. |
