Osmo doesn't turn on
2472 6 2018-2-11
AI_Kuz
Flight distance : 23999 ft
Hi! I have some problems with my DJI Osmo (model OM160).
It doesn't turn on.
This link to Video.
I try to update firmware but It wasn't successful:
========== 2014.01.01 00:00:08 remo-con disconnect======
Packet: OSMO_FW_V01.06.02.10.bin
Upgrading ...
Result: Success.
========== 2017.11.03 22:29:08 =====================
Packet: OSMO_FW_V99.99.99.99.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Packet: OSMO_FW_V01.11.02.70.bin
Upgrading ...
Thanks in advance.
2018-2-11
The latest firmware version of Osmo is v1.11.2.70, please make sure you download the correct firmware.
Please refer to the tutorial video below to update the firmware again, when the indicator becomes solid green, delete the firmware in SD card and reboot the Osmo.
If the right indicator is still solid red, please try to wipe the copper sheet inside the battery compartment with 95% alcohol and the cotton swab. Let the alcohol air dry. If it does not work, wipe the battery contact with alcohol and cotton swab. Or you can try another battery.
2018-2-11
Mikey Z
Red light blinks rapidly---Your battery needs to be charged.
2018-2-11
AI_Kuz
Mikey Z Posted at 2018-2-11 18:49
Thanks for reply. Battery was full. I double checked.
2018-2-13
AI_Kuz
DJI Mindy Posted at 2018-2-11 18:36
https://www.youtube.com/watch?v=jvahCGAtZvU
I sure that i use Last firmware version (OSMO_FW_V01.11.02.70.bin) from your site.
I tried to create Online Service/Request Service but (S/N: 06PDDK10010451). But I see error message: "Sorry, no product information was found. Check whether the input serial number is correct or use "Product model".
In Product model tub I haven't found DJI Osmo, only Osmo Mobile.
What's going on?
2018-2-13
RafaelWilliams
Mexico
========== 2014.01.01 00:00:10 remo-con disconnect======
Upgrading ...
Result: Failed.
I have a similar problem.
I uses Last Firmware OSMO_FW_V01.11.02.70.bin and not showing network OSMO
I already made the two flashing tutorials and reset the wifi and it does not work.
Please any solution?
2018-5-8
ramiro simoes
Brazil
My osmo pocket has firmware v 01.10.00.30The newest is v 1.11.00.2.70 is it ok ?
When I Conect my DJI MIMO it does not advise me about upgrade..., and I can't do the upgrade.
Tank for yourt help
2021-1-11
