dennismurry08
Flight distance : 5442736 ft
what are settings on your gh4 such as fps, iso, etc? Are you getting the jello on the video recordings? This is what I use depending on what I'm filming...but its a good place to start. I use F8.0, 1/125, photo style is custom or vivid or scenery and I set all of them at -2 in the menu...record quality I use HD 60i but to match some ground cameras I also use HD 24, play with M or MOV or IA which is on the knob on top of the camera...try that and see if you still have jello...if not you can fine tune your camera settings..I would also check your gimbal rubber dampners and see if theres something going on there...maybe one came out or something. See if you have free movement on your camera to make sure its not hitting something...I've seen guys with the camera mounted to high and it hits the top verticle bar which of course will give you jello and later a burned out gimbal. |
