Electro-Nick
Flight distance : 5989180 ft
Not saying it caused your trouble, but doing a compass calibration before each flight is like playing Russian roulette with your drone.
I think you've had a couple of things happen..
Inexperience.
Possibly a Bad compass calibration
Strong winds
Low battery power on one or both batteries
Rc sticks possibly in need of calibration too
I dont see any errors in the logs to show that the control link was disconnected (it would have done RTH earlier if it had), the fact you still had video feed also suggests that you still rc control of the aircraft too. I see a couple of speed errors, and a couple of RTH activations, along with several power errors. I usually see speed or yaw errors in my logs when I've been flying in windy/gusty conditions - a sudden change in speed or direction from a strong gust confuses the IMU and gives an error.
So, I think the following scenario is probably likely with the limited info I've got from your description and logs...
You took off, wind starts drifting the aircraft, you try the sticks but it won't come back because the wind is too strong for it's normal (p_gps) mode. You hit RTH, but again the wind speed overpowers the RTH cruise speed and it carries on drifting. You spend several minutes trying to bring it back against the wind, but thinking it's not responding. During all of this, the high winds mean the aircraft is drawing more power from the batteries and leads to a cell (or more) lowering voltage under load giving errors. The errors add to your sense of loss of control. Eventually the low power RTH kicks in and the aircraft attempts to fly back and makes it far enough to traumatise a poor unsuspecting bush...
Next time you fly in windy conditions be prepared to switch the aircraft to sport mode if it won't fly into the wind, that will allow the I2 to apply more power by increasing its max tilt angle, which will allow it to hit higher speeds. (If a wind speed is over something like 30mph in the normal p-GPs mode, then there's a risk the aircraft can start drifting as it won't compensate enough for the wind speed to hold position.) if it drifts in sport mode, then it's going to go anyway - just land it somewhere quickly, don't just stand and watch it go, and don't rely on RTH it isn't infallible! Lowering your altitude would probably help too as wind speed increases with altitude, so going lower might mean lower winds and less drift... meaning you might be able to fly into it, or at least reduce the rate of drift enough to hover or land somewhere.
If your I2 is still In flying condition, then do another IMU calibration making sure it's on a level surface and that it's done immediately after starting the aircraft up & when it's still cool. After calibration, check the diff values are low and the bar is in the green section of the graph.
Now, find somewhere safely away from anything magnetic, no pipes, no reinforcing, no concrete, no cars etc make sure you've nothing magnetic on your person either, then calibrate the compass. Walk 20ft or so away after calibration and check the diff values are low and the graph is in the green too. If it's a good cal, then don't recal the compass unless either the I2 asks you to, or you travel 100 or more miles east or west from where you did the compass cal. (North south doesn't have same effect).
Turn off the I2 and calibrate your RC sticks from within the Go4 app - just to make sure they are fully working and giving full power commands.
Finally, if you fly on a partly discharged battery, then be careful. It's usually safe enough, but the batteries aren't going to perform at their best. I often fly down my batteries after they've gone into storage mode at 55-65% charge and don't have problems. Those flights nearly always show the battery voltages dropping rapidly under load (e.g. When climbing), then stabilising when the aircraft is hovering. I always fly very conservatively if the battery isn't freshly charged or above 90%, or if it was used for a flight the day before and left overnight.
