stuka75
Flight distance : 85682 ft
Since there is no camera and gimbal, the app is not working. However, you do have the rc light green. "When you power up, start the rc/controller first, then the ac. Once the rc light turn Green, it will take a while for the aircraft to warm up. Once, and if the rear lights blink green slowly, you should be able to star the motors by using the csc movement on the sticks. Often when the camera and gimbals;e is removed, the ac and controller loose bind. Unfortunately, You cant bind them without the camera and gimbal. Catch twenty two I guess. The aircraft will fly without a camera/gimble assembly. Hope this helps. |
