Hello everyone
My name is Manuel and I am spanish from Valencia, sorry for my poor english I write with a translator.
I have a PH4 Pro about 3 weeks ago, before receiving it I was watching several videos about its operation.
When I received it, I fully loaded the drone's transmitter and battery, and then following the instructions I performed the calibrations, including sensor calibration using DJI Assistant 2.
On the terrace I did some start-up and lift tests of the aircraft, working correctly (I have to say that I use mode 2 in the Master Stick Mode), but when I want to move the aircraft to the right, left or forward, backward, the right stick does not respond correctly, working only occasionally and intermittently.
Thinking that there could be interference on the terrace produced by metal objects or electrical areas, and that this was the reason for the errors, I waited to perform the tests in open space.
This Saturday I went to an open area with the drone calibrated and the problem is the same.
I tried the flight in simulation mode (Academy), and the right stick responds perfectly.
I am trying to solve the problem as soon as possible and know if it is the aircraft's fault or configuration problem, to decide if I return it to the store where I bought it.
Aircraft 01.05.0300
Remote Controller 01.04.01.00
Precise Fly Safe Database (for Aircraft) 01.00.01.08
Precise Fly Safe Database (for App) 01.00.01.08
Basic Fly Safe Database 01.00.01.06
Greetings and I hope your help
