Mavic Air Unstable when dropping altitude?
2468 18 2018-2-12
cantflyalick
I only have one flight under my belt, and no time right now to retest this, but has anybody else noticed a sort of unstable rocking as the air is descending? I was happy with how it performed everywhere else, but in descent it had these noticeable rocking moves side to side. I saw it mostly just with my eyes and not in my video but just curious if others saw this behavior. I’d say winds were about 10-15 miles per hour. Thanks.
2018-2-12
RocketChap
Flight distance : 902034 ft
This may be no more than you would expect from a drone descending into its own prop wash. I get it on my Mavic pro. you can hear the motors trying to rapidly adjust.
2018-2-12
RocketChap
2018-2-12
cantflyalick
RocketChap Posted at 2018-2-12 16:51
Thank you for the reply. YEah I am not very experienced, that sounds exactly like what it was, just lowering in the instability of the air below it. Thanks again.
2018-2-12
Jeff7577
Flight distance : 1916821 ft
It’s probably trying to avoid a vortex ring stall which was common on older phantoms
2018-2-12
DJI Thor
Flight distance : 13602 ft
Hi there, please ensure that the drone has updated to the latest firmware, try to do an IMU and compass calibration, keep the sticks controlling smoothly. See if it helps to optimize the issue. Or you can provide us with a video so we can help to confirm. Thanks.
2018-2-12
Tom_A
Flight distance : 899951 ft
I have noticed this with every drone I have flown.
2018-2-12
cantflyalick
Tom_A Posted at 2018-2-12 21:38
Thanks. I gotta say I did not notice this with the spark, which is the only other drone I’ve flown. Maybe because it has a slower descent rate?
2018-2-12
Mullheliflier
Flight distance : 12305135 ft
My Mavics do the same. As mentioned above it is probably the aircraft trying to remain stable in its own downwash. A bit more forward movement should reduce it.
2018-2-12
Tom_A
cantflyalick Posted at 2018-2-12 22:39
No, it gets worse with a faster descent rate which I think is why the Spark and other "Camera" drones descent slower. The faster it descends, the less power it has to work with to remain level.
2018-2-12
drown84
Flight distance : 176312 ft
This is why I always decend with some forward speed...not a good idea to come straight down with a drone, really unstable.
2018-2-13
lovec1990
Flight distance : 36158 ft
Slovenia
drown84 Posted at 2018-2-13 00:16
i mostly land my Mavic PRO verticaly but i did notice this behavior but ignored it becouse drone  was quite stable
2018-2-13
sky6105
Flight distance : 345653 ft
When descending rapidly try slipping sideways to avoid your propwash.
2018-2-13
Spaceman_66
Flight distance : 82323 ft
I have noticed it happening, more so with the MA than with the Spark. I don't see it visually so much as I can definitely at times hear the rotor RPM/speed variations as it compensates as necessary while coming straight down, which I sometimes do when setting up for a specific shot so I know exactly where the AC will be and therefore just what the "reveal" will be looking at in the terminal phase of landing. Haven't tried a really fast descent, but I can certainly see from the physics involved where that would likely make it worse (e.g., coming down really quick in sports mode). FWIW, I have never to date seen any sign of it in the (stablized) camera footage, tho. Good ideas to translate a bit while coming down to minimize descending thru your own turbulent prop wash.
2018-2-13
Aeromirage
Flight distance : 1778045 ft
This is definitely prop wash.
Unless it is windy, always move slightly forward when descending.
I never fly backward when descending. This can get dangerously close to a CSC which may shut down the motors.
2018-2-13
eYeSkYeYe
Croatia
You are experiencing spiral slipstreaming in fluid colloquialy known as a propwash effect. That pretty much means you are descending your bird wrong. Counter measures are already given above.
2018-2-13
Brad Bilger
Flight distance : 14843274 ft
Google "Vortex Ring State."  In early models and in some Helicopters, descending too fast straight down can cause the aircraft to crash.
2018-2-13
fans473e667d
Flight distance : 620600 ft
Singapore
This will only happen if you descend fast especially in sport mode
2018-2-13
AG0N-Gary
Flight distance : 700846 ft
Brad nailed it.  Look up VRS.  It has crashed many helicopters when pilots didn't catch it in time.  Sounds like you were descending too fast.  As others have said, do some horizontal flying while descending for more stability.
2018-2-13
