LoSBoL
Flight distance : 666483 ft
hallmark007 Posted at 2018-2-12 15:15
Two things, if your drone is within 20 metres of home it will just land, if you want to change this you have to enable in your app.
Second if you are using app to RTH you may be just sliding the land command.
This is a little confusing to me, are you talking about a RTH triggering by itself when it reaches the "H" on the battery bar and then innitiating a different procedure then pressing RTH yourself?
I understand that when a battery reaches 'critical' it would land immediately, but I have done nearly half a battery of RTH testing (because of the flyaway topics I wanted to see for myself how the MA reacts to different circumstances) and it doesn't land immediately if the HomePoint is within 20 meters if you initiate the RTH yourself. The following things happen when I initiate RTH:
Homepoint < 5 meter, initiate landing
Homepoint > 20 meter, ascend to 20 meters (conform set RTH hight setting in the app) and fly to, and land at the Homepoint
Homepoint > 5 meter and < 20 meter, fly to Homepoint and land at Homepoint, if craft was higher then 2,5 meter, it retains its level flight to the Homepoint. If lower, it would go to 2,5 meter hight and flyes to Homepoint.
