Inspire 2 FIX for Propeller Vibration & Rotor Detachment / Crash
22604 209 2018-2-12
Elektrica Atellani
Flight distance : 9674836 ft
Rodger8 Posted at 2018-2-16 05:31
Really, not my kind of forum. A post and one of your photos is up and running. It received 20 views in the first 2 hours.
Thanks! Cool!
2018-2-16
Elektrica Atellani
rustydiver Posted at 2018-2-16 10:23
How much are these going to be for a set?
Dear Rusty,
We’re still estimating costs, etc.
It will probably be around 140 / 150 USD and the first bits should start shipping in +/- 45 days.
We will keep you informed.
2018-2-16
Elektrica Atellani
RichJ53 Posted at 2018-2-15 13:48
Yes, I agree with you and Elektrica  has a very good solution to add a bit more safety to the Inspire 2.  DJI does not believe there is a problem with their design and many are flying without issues. So, for folks that are worried about this happening to them,   can buy extra piece of mind.
Rich
I don't have an issue on the current I2, but I had issues in the past. For piece of mind I currently swap props every few of flights or two hours. We engineered this solution for my own peace of mind, you never know and no matter what it will make the I2 more solid, even in case of small accidental bumbs. We worked with a person (antonio) that engineered a lot of Technogym machines, as well as Suomy helmets, Yamaha parts, etc. (More or less many, many cool objects), so it was a lot of fun to brainstorm with such a prolific and smart mind. Rather than just a very functional, but rough looking solution, he / we also added some elegance to it, trying to integrate it as much as possible into the stunning design of the Inspire (such a glorious looking bird).
2018-2-16
Matthew Dobrski
Flight distance : 1831050 ft
Raju Chaudhary Posted at 2018-2-14 08:04
The motor mounts are glued perfectly by DJI and should not dismount ever ! I have done this just for my own satisfaction.
You're right, my friend. Kudos for you!
2018-2-16
Elektrica Atellani
Matthew Dobrski Posted at 2018-2-16 11:47
I still would not start drilling the Inspire I don't think it's a very sound idea. You definetively void any warranty, as it's clearly been tampered with and you cannot roll back.
2018-2-18
MadProps
Might it be possible to add a standard 1/4-20 boss on the bottom  to accomodate some hand catch handles or other future add ons?
2018-2-18
Matthew Dobrski
MadProps Posted at 2018-2-18 10:37
Everything is possible, if you're skilled enough and willing to sacrifice a warranty ...
2018-2-18
Elektrica Atellani
I would not want to add anything on a that structure, as it's a safety feature.
2018-2-18
Matthew Dobrski
Elektrica Atellani Posted at 2018-2-18 04:04
I wasn't cheering at the idea of drilling ... However, the statement that the adhering technology is sound and viable, made me so agreeable ...
2018-2-18
Elektrica Atellani
Elektrica Atellani Posted at 2018-2-18 12:17
Just for the record, this accessory would be absolutely non intrusive, it does not bolt into the Inspire, nor it uses or taps into existing screws, etc.
2018-2-18
Elektrica Atellani
Matthew Dobrski Posted at 2018-2-18 12:18
I did not do a whole study on it, but drilling might weaken the CF structure. It's just common sense. Beside, you definitely void any warranty, as the holes are really intrusive.
2018-2-18
skypal
Flight distance : 560256 ft
Hey Guys, don't want to spoil your excitement here but this seems to be a much simpler approach to me.
2018-2-18
Elektrica Atellani
skypal Posted at 2018-2-18 15:13
[view_image]
It's already been discussed widely here or in other forums. different solutions, much different and also with different functionality. It's also been discussed why they are so different and I don't want to bore anyone, but if you want I will do so again.
2018-2-18
Elektrica Atellani
mixchief Posted at 2018-2-15 10:19
yes you are right, however one of my motors came a little loose maybe due to an out of balance propeller ( I haven't confirmed that) causing a vibration that gave me jello, I don't know if it might benefit from additional bracing.
The accessory would keep both motors connected to each other and with the same angle, even if one came loose. In theory it should make things better, but it has not been tested with that specific situation.
2018-2-19
MadProps
Matthew Dobrski Posted at 2018-2-18 12:10
I was suggesting the possibility of manufacturing this new bracket to include an integrated 1/4-20 mount on the aftermarket reinforcement brackets, not altering the existing airframe.
2018-2-21
Matthew Dobrski
MadProps Posted at 2018-2-21 23:56
The placement of hand-catching attachments must be carefully determined and has nothing to do with position of aftermarket motor mount reinforcements of any kind.
2018-2-22
Cougar1
Flight distance : 924393 ft
[view_image]
Agree with this post, it seems to be the most elegant solution if you are concerned about motors falling off.
Another solution might not be so good looking, but looks to be very good and cheaper as well.
2018-2-22
Huebi
Flight distance : 1539337 ft
Well, everyone thinks their invention is always best. I think everyone has to figure that out for themselves.
I used this version: https://www.pimp-your-kopter.de/ ... cherungsklammer.php
2018-3-2
Elektrica Atellani
Huebi Posted at 2018-3-2 22:51
I used this version: https://www.pimp-your-kopter.de/dji-multikopter/dji-inspire-2/zubehoer-dji-inspire-2/i2-sicherungsklammer.php
Hi, they are completely different solutions and with greatly different purpose and performance. The solution you mention clamps to the arm and screws into the engine cover in the attempt to double what the I2 already does, just more secure. It will not prevent rotation and if the screws become loose, you will end up with the same problem.
Ours accomplishes the same thing (And more) but DOES NOT screw into the motor cover, which we assume was not designed to hold clamp and engine using non standard screws. The engine cover is an aesthetical bit and you're tapping into it to hold an engine. Ours relies on a system that will not screw into the Inspire 2's original design andalso prevent rotation of the engines by keeping the in sync. Most of the work is delegated to the accessory, which we think it vital. Our accessory has also been designed to integrate into the Inspire 2's design, rather than looking like a homemade bit with visible screws..
I am not saying yours will not do that one thing, but it will certainly not do what ours does, nor guarantee that your warranty will be voided, as you are replacing parts of the bird and it will certainly not prevent the rotation of one or more engines. They are simply not even close in overall purpose, design and execution, they just have one thing in common, but not executed with the same sophistication in mind. Anyway, we're not yet in production and who knows of we will produce it. So far we've been flying with a prototype and clocked 100+ hours between 2 birds. So far, so good.
2018-3-3
Anderjon
This looks good when attached to an I2 that is in perfect working order (as in the video), but do you have a similar video of it attached to an I2 that has a loose motor to demonstrate that it actually works?
I think the concept is great, but not if only works in theory. A solution is really only a solution if it can be shown to work when it’s actually needed.
Can you share this kind of testing that you’ve done please?
2018-3-3
DragonFly-UAS
I am interested too! Just sent you an e-mail, please add me to your list. Thanks
Any names yet?
- Rotor Tendon
- Motor Tendon
- ESC Lock
- Motor Radius Lock
- Oh Shoot Bar!
2018-3-3
Huebi
Elektrica Atellani Posted at 2018-3-3 00:55
Well, just as the clasp of www.Pimp-your-Kopter.de holds the engine, it can't fall forward or turn left or right. It is a good support for holding the engine, just like all other holders. It contributes to the additional securing. No one can say exactly whether and to what extent these solutions will hold up. But it's definitely better than doing nothing. And for 59 € a good solution and a fair price.
https://www.pimp-your-kopter.de/ ... p#861071a8990fe1203
2018-3-3
Elektrica Atellani
Huebi Posted at 2018-3-3 02:47
https://www.pimp-your-kopter.de/dji-multikopter/dji-inspire-2/zubehoer-dji-inspire-2/i2-sicherungsklammer.php#861071a8990fe1203
I agree, but they're just not the same, this is cheaper, more intrusive (You still have to bolt to the I2 with screws) and has less functionality. I am mostly concerned about hooking to the Inspire's bottom engine cover, which is meant to hold a light cover in place, not to do what the clamp tries to do. Anyway, anyone is free to to their own way...I just tried to develop a refined, good looking, functional and non intrusive solution, something that does not tamper with the I2 original hardware. BTW, if the clamp becomes loose, your engine will fall off and rotate just as much, ours have a series of ideas behind it that aim at preventing a series of possible failure scenarios. Like I said, two different products and quite different levels of functionality and sophistication. there's many, many man hours behind the design, thoughts and engineering in ours, a lot more than it looks and it's anything but simple to put them all together when nobody thought about it before.
2018-3-3
Elektrica Atellani
DragonFly-UAS Posted at 2018-3-3 02:40
Any names yet?
I did...Thanks!
2018-3-3
Elektrica Atellani
Anderjon Posted at 2018-3-3 02:38
We're waiting for pre-production prototypes, which are much better than the prototype. The accessory will be substantially more refined. The proto clocked plenty hours on two I2s So far everything is perfect, so we expect the pre-production to be just about perfect, as it will be objectively better from all perspectives.
I will keep you posted.
2018-3-3
Huebi
Elektrica Atellani Posted at 2018-3-3 03:27
It's sad that you're trying to talk another product down. Do you need it? Just because it's expensive doesn't always have to be good.  It can always solve everything, even your system is not the perfect solution, but very expensive. I also don't see that a CFK tube protects the motors from twisting.  It does not have to be beautiful, but light and practical. With the bracket of Pimp-your-Kopter. de nothing is changed at the I2 itself. So no guarantee loss. You also have to fix your system to the I2, which is a change to the I2. www.Pimp-your-Kopter.de's solution therefore makes more sense than a CFK Tube. https://www.pimp-your-kopter.de/ ... cherungsklammer.php
2018-3-3
Elektrica Atellani
Huebi Posted at 2018-3-3 04:15
It's sad that you're trying to talk another product down. Do you need it? Just because it's expensive doesn't always have to be good.  It can always solve everything, even your system is not the perfect solution, but very expensive. I also don't see that a CFK tube protects the motors from twisting.  It does not have to be beautiful, but light and practical. With the bracket of Pimp-your-Kopter. de nothing is changed at the I2 itself. So no guarantee loss. You also have to fix your system to the I2, which is a change to the I2. www.Pimp-your-Kopter.de's solution therefore makes more sense than a CFK Tube. https://www.pimp-your-kopter.de/dji-multikopter/dji-inspire-2/zubehoer-dji-inspire-2/i2-sicherungsklammer.php
I've been discussing the same 'comparison' before, some people even compared this solution to folding propellers (???).
If you compare this to a clamp, I am entitled to express my opinion and point out the number of differences, which are, forgive me, quite a bit.
If you compare a bicycle to a a motorcycle and assume they are similar and achieve the same purpose, I am entitled to let you know that one has an engine, probably better brakes, can go faster, can go uphill easier, etc. Sure, you can tell me the bicycle does not use gas and it's generally cheaper, but beside having two wheels they are just not the same thing and (Generally) speaking one is quite a bit more complex than the other.
Simple is not always better, in some cases simple is just obvious.
Clamps are the most obvious partial fix, but they carry a series of drawbacks with it.
Maybe I am not good enough at explaining these stark differences in practicality and performance, but ,for example, by not using external screws that bolt into the motor cover, as trivial of a difference this might seem to you, it does make a difference to us, as it was a very precise and thoughtful decision (Not wanting to alter the original parts of the Inspire 2) VS the obvious.
The differences are simply too many to compare them IMHO, but again, it's just an opinion. Your solution is good if you accept the number of drawbacks that come with it VS the fact that is cheaper, which is the only advantage minus the missing functionality., etc. etc. etc
This is not a battle of the cheapest accessory, it should be about what is making the I2 the safest with available solutions. There's plenty clamps, the one you mention and others, but nothing more than that, unless you consider our solution, which is obviously very different and with different, higher performance (and cost if you will).
I will be just happy to make my I2 as safe as possible in the smartest way that I know of, even if it's costing me time and money to create it. I could have made clamps in house in hours, but chose to work on a sophisticated solution... Rest assured, I am happy that you are happy with your solution. We can agree to disagree. Peace and have a nice weekend.
2018-3-3
Huebi
Elektrica Atellani Posted at 2018-3-3 04:46
I think you are confusing the holders from Germany with the ALU holder from New Zealand. No external screws are screwed into the I2 for the brackets I use. This shows me that you didn't really care about the product I use. You're just trying to make your product look good. But I just don't see any advantage in your solution except that it's way too expensive. But if you are satisfied with your solution, it's all good, have fun with it.   I will stick with this product: https://www.pimp-your-kopter.de/ ... cherungsklammer.php
2018-3-3
Elektrica Atellani
Huebi Posted at 2018-3-3 07:13
I think you are confusing the holders from Germany with the ALU holder from New Zealand. No external screws are screwed into the I2 for the brackets I use. This shows me that you didn't really care about the product I use. You're just trying to make your product look good. But I just don't see any advantage in your solution except that it's way too expensive. But if you are satisfied with your solution, it's all good, have fun with it.   I will stick with this product: https://www.pimp-your-kopter.de/dji-multikopter/dji-inspire-2/zubehoer-dji-inspire-2/i2-sicherungsklammer.php
Sure,  you are right on the screws. it's still a bicycle though. It's not that I don't care, it's still a partial solution and quite frankly I did not look at it in details, because they're all the same with slight variations, there quite a few clones around.
I am looking at actual performance / benefits / safety of the drone, rather than variations of the same thing, as it's still clearly an incomplete (Yet cheaper as you mention) solution. Bicycle it was and bicycle it still is. No thought went into it.
I don't know who copied who, but for sure they are all the same partial solution, except one.
I don't try to do things well for the sake of it, I try to do it to improve the bird. You should be able to appreciate the originality and functionality of a superior solution, rather than promoting a clone (Unless they made it first, which would make all the others clones, but I frankly don't care much).
There might be a better solution than ours coming, who knows, but as of today, this is the best solution available. As price goes, Ferraris and Fiats don't cost the same for a multitude of reasons, including performance and anyway you can find clone clamps that cost $200, but are probably made better than  the one you keep linking, but I am sure you know better than I do, don't you?
2018-3-3
Huebi
Elektrica Atellani Posted at 2018-3-3 07:59
Yes, it is always funny when the cook praises himself and says that his food is the best.
Your pole is simply not much better than any other solution. You just want to sell it expensive.
Get off your high horse.
There are two better solutions than yours:
1. https://dronedepot.co.nz/inspire ... e-2-feet-clamp.html
2. https://www.pimp-your-kopter.de/ ... cherungsklammer.php
2018-3-3
Elektrica Atellani
Huebi Posted at 2018-3-3 08:45
You're just spamming the thread with more clamp clones! Ha ha ha!
In this whole conversation you hardly argue the technical aspect of things (Barely), but rather play the usual empty argument card. It's not about cook, how tall you are, the color of my drone, the weather, but it's about the safest solution out there and the "Return of the clone clamps' is simply not the best solution.
You perfectly know how technically poor these clamps are, yet you make this about your personal battle against obvious facts (The ones you hardly argue, except a screw and pricing). Happy you love your FIAT, I already acknowledged have every sacred right to do so, but take it as it is, and as partially effective as it is. Other than that, please stop spamming, or just keep going if that makes your day a better one. It's a free World.High Horse??? Creating useful safety solutions becomes a curse for you. Weird!
Fly safe.
P.S. I am not even sure we will ever produce this solution, so you're wasting your time. At least argue with me if there will be ever a product made, or just keep spamming
2018-3-3
fansa84fe8a4
Flight distance : 3 ft
This thread is filled with spam.
2018-3-3
Altitude Drones
Flight distance : 1488520 ft
Elekrtica, I think your design is a great idea and also looks great on the I2.
Months ago I had the large 3D plastic clamps made professionally and they look cool (military style), I also have faith that they would stop the motor from rotating or separating as they are both bolted and held on with very strong 3M tape. They also have a large surface area of contact with the arm and motor housing.
As far as I can see it's great that people have made efforts to fix what could be a fatal flaw of the I2. The arguments on this thread should be been had by DJI engineers so they can come up with a decent answer.
Well done for all those with the skill and expertise for coming up with solutions. Much appreciated!
2018-3-3
Elektrica Atellani
Altitude Drones Posted at 2018-3-3 18:25
Thanks Altitude Drones, I am quite sure that DJI has addressed or is addressing the potential problem. I generally change my propellers very often (every couple of hours of flight). Sure it's not the cheapest way to go, but I rather spend a few $$$ on new props, rather than being sorry. Even with the accessory mounted, I still swap the props, just less often than before (Approx. every 4 hours). As soon as I hear the rattling coming, I change them. The I2 is too much of a drone, in every sense, to let it fall or get damaged.
Like I said, I am quite sure that DJI is on top of it. Even if they're not extremely vocal, they gave us freedom of talking about almost everything, which I find commendable.
All said and done, I truly adore the Inspire 2, as much as I love the Zenmuse X7 and I cannot wait for the next evolution of this gorgeous mean machine.
Thanks again for your kind comment.
2018-3-3
Rob W
Flight distance : 94390 ft
Sweden
Elektrica Atellani Posted at 2018-3-3 18:33
Hope production will start, Electrica. If it will, I will buy.
2018-3-5
Elektrica Atellani
Rob W Posted at 2018-3-5 02:19
Thanks! I will keep you posted
2018-3-5
fans4f8954b4
Flight distance : 18275925 ft
Elektrica Atellani Posted at 2018-3-5 02:20
Hi Elektrica
Just wanted to know if you tried putting the Inspire 2 with your system in the stock DJI box.
i am sure that we mast fit the foam to insert the bird.
2018-3-14
Elektrica Atellani
fans4f8954b4 Posted at 2018-3-14 06:45
Hi Elektrica
Not yet, I am waiting for the final prototype to get here (Hopefully before the end of the week, so it can be tested. We should ship in a month and pre-orders will starting day, after we verified the last proto.
2018-3-14
fans4f8954b4
Elektrica Atellani Posted at 2018-3-14 14:15
Thanks, please PM me when preorders start.
2018-3-15
Mr.Mister
Flight distance : 862854 ft
Any names yet?
DJI_CYA ???
2018-3-15
