Nigel_
Flight distance : 388642 ft
dorbot Posted at 2018-2-14 00:38
There is magnetic variation if you move across the planet, but its normally only a few degrees if you travel 100 miles. Depends where you are. Aviation maps have magnetic variation lines.
Nigel said,
I don't think it has a gravity sensor. It has a 6 axis accelerometer so can accurately make changes to it's speed and orientation, but an accelerometer measures acceleration, if the aircraft is hovering perfectly still then there is no acceleration, not even acceleration due to gravity, and so the accelerometers will measure nothing and there is no way to tell which direction is up or which direction is north except for the compass.
The GPS could be used to work out where north is, but only by taking a short journey to find out how the GPS location changes with movement, or a longer journey if you want it accurate, that is how it works out that there is a mismatch between the compass and the GPS, however the result will be inaccurate if there is any wind since it doesn't have an anemometer or wind vane, or even air speed sensors, so it doesn't know what effect the wind is having - in a strong wind it may need to fly north west to fly north but rotating 180 degrees isn't going to take it south, it would need 270 degrees for that. If it is just hovering then the GPS can't even guess at a heading.
The magnetic variation across the planet is calibrated out every time you take off, that is the reason that taking off from near a magnet is no problem, it is when you move away from the magnet that you run into trouble. If this calibration requires a big correction then it gives you a warning so normally you only run into trouble if you either ignore the warning, or manually recalibrate to remove the warning. You should always change location on a warning, not recalibrate. |
