djiuser_AYUOtXMp6ykb
Brazil
Hello,
I'm having a problem with my phanthom 3 standard battery.
When charging the battery blinks the third led, withdrawal of the energy and I press the button to verify the load and all the leds are access indicating 100% of load.
When placing the battery in the drone, the message "solution: to ensure battery health, do not power off the aircraft until discharging it to 5% after landing. is displayed in the DJI application.
I have already done the procedure of unloading up to 5% and charge the battery completely, but the same problem occurs, the LED keeps blinking, the charge is 100% when I check the battery and the error message appears in the application.
Has anyone had a problem with the battery and solved it?
The firmeware is up to date, the aircraft as well.
How do I open a call on the dji support?
I thank you for your attention.
