DJI GO 4 Flight Records won’t sync on any device
3526 17 2018-2-13
Kidologist
Flight distance : 4415722 ft
This issue has been confirmed with many other operators in a Facebook group, that flight records will not sync. I have updated app and tested several devices even reinstall DJI GO 4. Is there a system failure right now?
2018-2-13
DJI Elektra
Hi, there. Please tell me the model of your mobile device. Did you try to use mobile data? Please change a wifi environment for further check. Thanks for your support.
2018-2-13
dji TO88
Flight distance : 4678 ft
Try to log out of your DJI to go and log back in I tried this and everything synced after that procedure.
2018-2-13
Kidologist
IPhone X - tried log out and in,  o luck. Even flew and still no luck.
2018-2-13
csreed
Flight distance : 834816 ft
I've been having the same problem.  It started a day or two ago.  Logout/login didn't fix it for me either.
2018-2-13
userdfb657e1d8
Flight distance : 40883 ft
Me too, iPhone 7 Plus, tried everything but still cannot sync
2018-2-13
w4pbk
Flight distance : 324806 ft
Same issue for me on iPhone X. Tried reinstall the app and I still doesn’t work.  I was only trying to sync my last flight so if I loose that data for that one flight by  reinstalling the app, It’s no big deal.  Work fine on my iPad mini 4. Just not the iPhone.
2018-2-13
mike.conner
Flight distance : 178468 ft
New Zealand
Me too. iPhone 7, latest version on DJI GO 4, stopped after the last update.
2018-2-13
mike.conner
New Zealand
Just tested again, all working now.  Thank you
2018-2-14
Kidologist
Seems they fixed whatever was wrong, as it is working now. Maybe system update or something.
2018-2-14
Tom_A
Flight distance : 899951 ft
Syncing flight records doesn't seem to work the way I would expect it to. I would expect syncing to just add the new records, but when I look at my flight distance on the forum, it will go up when I sync again without actually flying again.
2018-2-14
Kidologist
Tom_A Posted at 2018-2-14 11:18
I have to sync after every flight to get the values to increase/update.
2018-2-14
Tom_A
Kidologist Posted at 2018-2-14 12:28
Yes, but if you sync twice after one flight do the numbers increase twice. I think I have way more flight distance than I should have.
2018-2-14
DJI Diana
Flight distance : 2408 ft
Hi guys, we are sorry for the inconvenience and thank you for the feedback. This issue has been reported and fixed as confirmed by our experts from the headquarters. Please try syncing flight records again.
2018-2-14
fans3bd0e842
Flight distance : 1800738 ft
Still not working for me and my software updated DJI Mavic Pro.
2018-2-20
eXtremeSG
Flight distance : 25843 ft
Singapore
Not working for me now. Logged out / in - still won't work. Stops at 31%.
2018-9-11
Alexmimo
Russia
Have the same problem with  DJI go app on my ipad and on Phantom 4 Pro+ DJI app too! Mode SYNC ALL. Dec 21 2018.
2018-12-21
djiuser_lmlQzLsbKthA
Flight distance : 70899 ft
My flight that is not syncing on the app
2021-12-28
