fanscc292e56
Flight distance : 1486811 ft
The last few times I've flown on my original A set of batteries, I've run into a concerning problem. Mid-flight, I get a warning that says "battery status error." Usually this just happens with one out of the two batteries, however on one occasion this happened to both batteries and I was forced to land immediately.
You can see the issue in the photos I uploaded.
I'm running on the latest firmware for both the I2 (and batteries) and with the Cendence and CrystalSky 7.85" monitor- both updated to the latest firmware/software as well.
I have another pair of batteries that I have never had this issue with- it's only my "A" set. The issue is also spotty- I've had it happen several times in a row and then not happen, and then happen again, etc.
Either way, I'd like a solution- whether it be a fix (if possible) or replacement of this possibly faulty battery set.
battery menu
