OSMO Mobile 2 -Active tracking not working
12Next >
35861 45 2018-2-13
Vignessekar895
I bought a DJI OSMO mobile 2 recently.When I use the active tracking to select the object,it is not able to sense or track the object and goes out of control.I am then getting a pop up that “subject lost....searching” .I use Iphone 7 plus
2018-2-13
tnovak
Same issue for me. Super disappointing...
2018-2-17
joepatb0b
Flight distance : 32198 ft
same, I think it's the new firmware. when I first tried it it was solid now it's finicky
2018-2-17
Reinaldonormand
Same issue to me. iPhone X
2018-2-17
Oneplus 5t
Réunion
Same issue here, Oneplus 5t (android)
2018-2-20
aluchips
same problem here with iphone 7. and there doesnt seem to be any answer why this happening. been searching everywhere...
2018-2-20
HollandJim
Beyond which phone, what version of App and Firmware?
I'm not having any ActiveTracking issues.
My device: iPhone 6s
Firmware: 2.1.0.20
APP:02     2.1.28(2861)
Are you newer or older? This is what we have in the Dutch store.
2018-2-21
fans3ed6bb11
Flight distance : 26014 ft
Switzerland
Same problem for me, I can select the subject but after the gimbal turn and goes out of control ...
2018-2-27
fansb63b2c33
I am having the same issue with my iPhone X, the gimbal just goes crazy. That's frustrating. =/
2018-2-27
fansb63b2c33
Hi guys! I just found out what's happening. Your phone orientation (portrait, landscape) should be UNLOCKED. Now it works just fine.
2018-2-27
fans7281a1db
Mine doesn't work in hyper lapse mode.  iPhone 7plus.  I have tried it before and after pressing record and it displays an error code.
2018-2-27
waterironbro
UNLOCK YOUR PHONE ORIENTATION!!!
2018-2-27
Hi all, sorry for the late response because of the holiday, like othe users suggested, please make sure the Portrait Orientation Lock of your phone has been turned off and then try again, please let me know if the issue persists, thanks.
2018-2-28
OsmoLondon2018
See my attached video at the moment DJI can not help
2018-3-1
Seitenwerk
Flight distance : 59400 ft
Austria
Same problem here: iPhone 6Plus with iOS 11.3
Once I select an object, even at perfect lighting conditions, my Osmo mobile starts to move up and down even if both the Osmo and the tracking target are perfectly still. The movement continues getting stronger until it completely goes nuts and turns into another direction and loses its target
2018-4-8
fansda8c7b36
i hade the same problem with iphone X, but it works just fine woth my samsung s6, hope it will be fixed in the next update
2018-4-9
djiuser_nygbiIiTzjtT
Having the same problems.  I have taken my phone off of orientation lock and the problem persists.  Any updates?
2018-4-17
VLOGNOSIS
Tracking worked for me, for following a basic object & when the OM2 was kept motionless on a tripod. In this scenario it worked well. It did not work well with a complex object, while being handheld. Sample video proof is available on my YouTube review.
2018-4-18
Chungheng
Cambodia
I used to have that problem as well. To solve that problem you need to check your phone’s lock screen. If it is lock, you need to unlock that lock screen
2018-5-2
fans0af1e19a
Chungheng Posted at 2018-5-2 18:08
Same, iphone5, locked info turned off, cant activate active track. Like in the movie above. Keeps a circle, doesnt turn into a square. Eventually if u lcik enough u hit zoom in or map for fotos , cause button is close. Last update, rebooted, any ideas?
2018-5-23
fans0af1e19a Posted at 2018-5-23 10:47
ActiveTrack is not compatible with certain phones (i.e. iPhone 5s and iPhone 5) due to limitations within the phones. Sorry for the inconvenience.
2018-5-24
fans2da3ee33
Seitenwerk Posted at 2018-4-8 05:50
Moi aussi sa ne fonctionne pas quand le tout sera corrigé
2018-5-28
djiuser_ZVe7GAx0sjML
fansb63b2c33 Posted at 2018-2-27 13:21
thanks for bring in the solution, awesome!
2018-6-25
Minato Uchiha
Laos
Me the same problem...
2018-7-9
Minato Uchiha
Laos
yeah...thanks...I can solve it now...
2018-7-9
sorka
Flight distance : 782582 ft
It sort of works on my Note 4 but it's flaky it can't stay locked on to a target very long before it goes to "searching for target".
It also also drains the battery from 100 to off in about 15 minutes and the phone gets REALLY hot. I'm going to return it and revisit it again if I upgrade my phone in the future, but for now the Note 4 does everything I need it to.
2018-12-14
fans0592b036
That’s it, spot on!
2019-2-11
djiuser_QhSDdgxJv6Gg
India
I purchased today and facing same issue. Mismo mobile 2 behaves weared. Not tracking subject and starts vibrating. DJI go app app hangs regularly. I am using one plus 6T. Disappointed.
2019-2-22
India
I am facing the same issue. Osmo mobile 2 is loosing object and gives message object lost and searching nad behaves weired. Not a single time it worked. I have just purchased it last week.
2019-3-2
India
2019-3-2
s.sharifi
Afghanistan
Same here with my iPhone 7.  Also when I connect my iPhone 7 plus to the gimbal, the bottoms don't work.
2019-3-31
aaminu
s.sharifi Posted at 3-31 19:52
All you need to do is turn on/off your orientation lock from the phone setting and unleash the potential of your Osmo
2019-4-6
jumping
Flight distance : 40141 ft
I think that's a iPhone term. Is there an android equivalent?
2019-6-22
jumping
Hi there, are we talking about just apple phones or and android? Im trying to find the setting in my galaxy s5. Could it possibly be that that model doesnt work ?
2019-6-27
fans9b804a4a
Hi man! Thanks for your advice, it works for me now)
2019-10-10
Abood Alalami
am using android system huawei p20 pro
and the active track mode not working before 2 weeks I try its working and auto rotation is on or off its still not working... may I know any solution
2019-10-16
Abood Alalami
am using android system huawei p20 pro and before one week it was working with me dji osmo mobile 2 tracking mode but now I don't know what is the issue I try to reinstall  the app and turn on auto rotate or off is not working any help plz
2019-10-16
djiuser_ZGfogmlVTGxe
Indonesia
Abood Alalami Posted at 10-16 11:04
Same with me. I using Galaxy S10+ active tracking is not working with my phone very sad
2019-10-17
fansacb87cb0
Flight distance : 16391 ft
Bosnia and Herzegovina
djiuser_ZGfogmlVTGxe Posted at 10-17 01:05
HUAWEI P20 LITE, same issue. It worked fine few days ago.
2019-10-17
fansacb87cb0
I found solution for these with "active track problem". Update from 02.10.2019. to version 3.1.58 is problem. Don't update or if you already did, uninstall the app and isntall version  3.1.52. From March 11 2019. Good luck.
2019-10-17
12Next >
