A CW
Flight distance : 1411492
Punchbuggy Posted at 2018-2-14 14:40
Agree, but I do note that the Phantom x is clearly a more solid construction. The Air, while still solid for it's size, is clearly flimsy in parts.
I'm particularly thinking of the prop spindles. I note that folded up, the Air sits on it's props and it's packed just under the top of the soft travel bag. A couple of good knocks there... Also, if you don't fold the prop arms back in the right order (which when closing is front then rear, and opening is rear then front), there's a temptation to force the front prop over the foot of the rear prop arm already there. Not an issue in the other order. That can't be good for the prop spindle either.
Hence - "if you look after it". Most of what you have written is not down to the drone. Fold the arms carefully every time, remove the props for transport/storage if you've noticed something that concerns you, maintain the batteries effectively, clean the drone after use and store it in the right place, fly it carefully and in line with the manuals etc - it is not a low quality product but quite the opposite. My MPP is in exactly the same condition today after 30+ flights as it was when I unboxed it in November last year. No reason why I will not be flying that drone in 2019 and beyond as I have my P4P since November 2016... These drones can and do last literally YEARS! The MA is no exception. Of course, they can also last just minutes too! |
