DJI Goggles and Spark
6084 10 2018-2-14
jangermann
Flight distance : 182680 ft
Denmark
Do it work?
Can I connetect the goggles to the RC and just fly?
OR do I have to start up the app on my Ipad, connect, login, disconnect, plug in OTG, ect ect...
I mean DO IT WORK as it should or is it still in develoment state?
2018-2-14
MJLSTUDIOS
Flight distance : 1540131 ft
I haven't been able to connect my goggles with the Spark. After I connect the goggles with the RC the goggle screen does not bring up the flight app.
2018-2-14
jangermann
Denmark
MJLSTUDIOS Posted at 2018-2-14 02:44
That sounds very strange.
The goggles ars sold as Spark compatible.
I was thinking about getting some, but I guess it is a no go.
2018-2-14
Hotwire
Flight distance : 10719 ft
Could this be related to the GO 4 app issue with OTG cable on Android?
2018-2-14
Tom_A
Flight distance : 899951 ft
I have been able to get mine to connect. You might want to check and update the firmware version on the goggles as there are definitely versions of the firmware that are not compatible. I think I get a little more reliable connection to my Mavic Air, but with the Spark, you can also use HDMI with an adaptor to your phone or tablet.  HDMI mirrors the device screen so that someone can view through the goggles while you fly using the screen.
2018-2-14
ZigZag
Yes, you can just connect the goggles to the Spark and fly without starting the Go4 app on your iPad.  Here is the sequence I use:
1. Power on the remote control and the Spark and wait for them to connect (green light on RC)
2. Power on goggles and connect cable (USB and OTG) to the goggles
3. Last make the connection to the remote control
Select & confirm video resolution, wait for the Home Point to be set and start flying.  I believe you might be limited on range by not starting the Go4 app first, but I have not personally tested this. I start the Go4 app on my iPad, check that everything is OK, then connect the goggles as a last step, usually once I'm in the air.  Love the goggles for both my Spark and Mavic Pro Platinum.
2018-2-14
DJI Diana
Flight distance : 2408 ft
Hi everyone, ZigZag is actually correct. With DJI Goggles, the Goggles do not lift the restriction on the aircraft. So if you are flying with just the Goggles and the remote controller without your smart device, you would still have to connect your phone before connecting the Goggles to lift the restriction. You only need to connect it once with the DJI GO 4 app and you may disconnect the app after.
2018-2-14
jangermann
Denmark
Hi.
Thanks for your answers. So the right procedure is (correct me if I am wrong)
2. Start GO4 on my smart device and let it connect to the RC via wifi
3. Power on goggles and connect OTG cable to the goggles
4. Turn off GO4 and disconnect the wifi connection to the RC
Two questions:
* Can the GO4 app be connected to the RC via wifi at the same time as the goggles is connected via OTG?
* Will the goggles ask, before changing "wifi mode" (like the GO4 app) if I travel to another country? OR do the goggles change the wifi mode automatic? OR do the goggles do nothing?
2018-2-15
ZigZag
Jangermann,
See my process steps on earlier post.  After plugging in goggles to the RC (last step) Go4 app will automatically disconnect on your device and the goggles will be active. I just leave the Go4 app running on my device even though it is disconnected while I go on a quick flight.
The other option is to do as Tom_A suggested and connect your device with a HDMI connection and mirror your device.  This makes switching between goggles and device easier as you keep the device and Go4 app connected to the RC and just use the goggles as a monitor. Since this is a mirror of the device, using modes built into goggles like head tracking gimbal would not be active.
Hope this helps.
2018-2-16
jangermann
Denmark
ZigZag Posted at 2018-2-16 17:47
Jangermann,
That is perfect.
Thanks. I hope to get the goggle next week.
2018-2-17
Seitenwerk
Flight distance : 59400 ft
Austria
Is this still correct? I have seen people claiming that since a recent update, the 50m limit ist removed for them by only plugin in the goggles.
2018-4-8
